Ultra-High Performance Stereo RCA to True Balanced XLR Converter
orchardaudio
Succasunna, NJ
All,
I have designed a stereo RCA (single-ended) to XLR (balanced) converter.
I will have both fully assembled and bare boards available.
Fully Assembled boards: 150 to 180 USD + shipping depending on interest
Bare boards: 12 to 18 USD + shipping depending on interest, see BOM in attachments.
Parts used are OPA1622 as initial buffer to OPA1632 for SE to balanced conversion.
Input impedance: is 47k
Output impedance: is 100 ohm.
Gain: 2.5V/V or 8dB (can easily be adjusted if you get the bare boards with resistor values)
Input Voltage: 9V
Onboard very low noise LDOs: LT3090 and LT3042
Please let me know if you are interested.
Thanks;
Leo
  • RCA_to_XLR_BOM_Rev1.0.zip
Matias
São Paulo, Brazil
Very nice.
But also a multichannel option would be great for AVR pre-outs with insufficient volts for feeding power amps.
orchardaudio
orchardaudio
Succasunna, NJ
Very nice.
You can get as many of these as you need for multi channel, these are very small. and you can daisy chain the 9V power supply to all of them.
sergeauckland
Suffolk UK
Interesting. Do you have a specification, especially for maximum output voltage and load driving capability. I use a number of RCA-XLR converters professionally, so am interested. I would also much prefer a 10 turn pot to set gain rather than changing resistors as trimming output levels is important.
S.
orchardaudio
orchardaudio
Succasunna, NJ
S.
I have not measured them yet, but I don't even think my audio analyzer will be able to measure the true performance of this circuit as the specifications for these parts exceed the measurement capabilities of my APX-525.
It essentially going to be completely transparent. The output voltage is limited to about 20Vpp (7Vrms) before its starts clipping due to the power supplies.
The output current capability of the OPA1632 is 150mA, considering the 100ohm output impedance it can drive any load with no problem.
There is no pot on this version, maybe in the future. However I am sure you would be able to wire a pot in if you wanted to externally.
MakeMineVinyl
Santa Fe, NM
All,
Input Voltage: 9V
Thanks;
Leo
Schematic?
airmail
I'd like these so I can run balanced a fully balanced setup with a 3700 - have you got cases in mind that these boards will drop into? Preferable want to run 9 channels.
orchardaudio
orchardaudio
Succasunna, NJ
I am in the process of designing cases for these now. The cases will be stereo (2ch) so you will need 5 of them to run 9 channels.
The cases will be similar to the PecanPi Streamer ones, but much smaller.
airmail
I can live with that, I'd look at building a little box for them - just can't be bothered messing about with PCBs.
orchardaudio
orchardaudio
Succasunna, NJ
For those interested in the DIY version you can purchase it on the website using code "rcaxlr" and get 20% off.
orchardaudio
orchardaudio
Succasunna, NJ
Images of the converter.
Some initial measurements:
Dashed lines are AP-525 in loopback mode. 22.4kHz BW.
10kHz Square wave (1.2MHz BW)
For some measurements looks like I am limited by the performance of my audio analyzer.
