- Joined
- Feb 23, 2016
- Messages
- 20,872
- Likes
- 37,894
Couldn't you solve your problems using a Mutec 3+ USB? Not an inexpensive solution at $1149.
https://www.amazon.com/Mutec-Generators-Distributors-Sampling-Converters/dp/B01LYVU3O6
https://www.mutec-net.com/product_mc-3-plus-usb.php
You can save a bit buying a second hand one. It can take digital input from any format and output it simaltaneously on all the other formats. I don't know if the reclocking it does would create problems (or perhaps you can turn that on or off).
