Understanding Balanced Audio (video)
MRC01
Pacific Northwest
... The convention for interfacing balanced to unbalanced is to leave the (-) balanced output floating and just route shield and (+) output to the RCA ground and (+) input respectively. ... Opinions vary a bit on how to connect a single-ended output to a balanced input and it somewhat depends upon the circuit configuration of the balanced input. You connect RCA (+) to balanced input (+), then decide whether to connect RCA (-, ground) to the balanced (-) input, shield, or both.
Thank you for responding Don! I hadn't thought on using an adapter ...
That works, but you may get elevated noise or distortion, as balanced signal paths rely on differential signalling to reject common mode junk, so may have worse performance when only 1 signal pin is connected. This affects some balanced equipment more than others, depending on how they're designed. Example: the Schiit Magnius.
Xii-Nyth
Winnipeg, Canada
Question, which I believe it was addressed slightly. Are TRS connection / plugs (like form a mixer or pre-amp) balanced?
aren't those the optical ones that look like rca? so they are digital? or am thinking of something else entirely
if they are those ones I guess technically not since its a single reference ground, but as long as it has a tolerance of 49% (or ~33% to avoid a floating range) it would be able to tell whats a 1 or 0 so it doesn't matter
in a perfect world any load device could just have any converters and amps built in and we just transfer all data over wifi instead of a cable, anyone who tells you there is signal interference is pretty much not telling the truth since its not like our devices constantly get sent incorrect bits over wifi since that would cause them to crash or make errors all the time
only problem is then you can't (easily) reuse the same hardware, and it would add weight to the devices. but theoretically there will one day be a perfect headphone so you will only need to buy something once, and the fully integrated components and circuitry could theoretically less dense than air.
Going further people would just have direct digital to neuron converters in the heads and I highly doubt there will be people claiming it sounds better when they plug into a wall with their \|7 2200000 [Gen 8 quantum currency] AudioQuest III synthetic carbon-plasma cables (carbon shielding at absolute 0, wiring at 3000 C, achieved with differential energy technology to block out noise) inspired by human mythology
if you see one of the guys just use scissors on his cable
DonH56
Monument, CO
TRS = tip-ring-sleeve and are used for many purposes, including sending stereo signals to headphones, balanced signals to other components, and effects loops in mixers and pro signal processing units. They are not optical. They are often used in place of XLRs to save space and for quick connections (not locking).
From a quick search (I use Sweetwater a lot so it came up first in my search): https://www.sweetwater.com/sweetcare/articles/whats-the-difference-between-ts-and-trs-cables/
Xii-Nyth
Winnipeg, Canada
TRS = tip-ring-send and are used for many purposes, including sending stereo signals to headphones, balanced signals to other components, and effects loops in mixers and pro signal processing units. They are not optical. They are often used in place of XLRs to save space and for quick connections (not locking).
oh haha, never considered those had a name!
JP
Brookfield, CT
Have always seen it called tip, ring, sleeve.
DonH56
Monument, CO
"Sleeve" yes, that is the usual nomenclature, sorry. Had a mixing console on my mind so "send" crept in. Corrected.
