I think there is a forth alternative: let me test the Lampi, sell it then and buy something that doesn't need a patch like this.
Stirring the pot one more time on this, as there's going to be an elimination challenge between these two components. The Lamp DAC puts out 3v, thereby overloading my Pass Labs Integrated Amp and causing it to clip. As a long-term fix, I don't want to go the RCA in-line attenuator route or insert a passive preamp in front on an integrated amp. The differences are irreconcilable and hence one of the components below will pack its styrofoam inserts and depart from my audio chain in great shame.
1) Pass Labs Int-60
2) Lampizator Golden Gate Dac V1 (R2R); SE, no volume control.
Now, in terms of system-matching, what would be the desired specs for possible replacement options? I need the input of the
ASR cognescenti on this.
If I keep the Pass integrated amplifier and replace the Lampizator DAC, then I imagine that most any DAC that puts out 2v fixed (or with volume control) would not overload my amp.
If I keep the Lamp DAC, and replace the Pass Int 60, what sensitivity specs should I look for in another integrated amplifier or power amp so that it is not over-driven by the Lampizator DAC? Would it be better to get a power amp (or an integrated with pre-bypass option) and use a passive preamp as an attenuator?
Thank you!
