USB DAC
Musichead
Hi everyone,
Can someone recommend a high quality portable USB DAC? Or are there any better ones that you can recommend??
Thanks in advance
Zek
It would be good if you could say what the price category is and a little more about the use of DAC.
M
Musichead
Good point…. Budget Up too $300 AUD …. Travelling so need it portable most of the time….
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
What headphones?
The Qudelix-5k is one I have and use most often.
If you don't have anything particularly power hungry, I'd start with them.
staticV3
How portable?
41hT8v3aR7S._AC_UF894,1000_QL80_.jpg 778ca047d4b4f14ac3b811c7cc8f5668_1024.png apos-audio-topping-headphone-dac-amp-topping-dx1-dac-amp-37774129332460_800x.jpg
Also, what headphones will you use with the DAC?
M
Musichead
What headphones?
Focal Celestee Shure 846e
M
Musichead
Thanks for your help… I’m looking for something more portable… I decided to get a Qudelix 5k
AdamG
Enjoy the Music your way…
Moderator
Reality
When you start using the EQ/PEQ function of this little beast you will be ecstatic and want a second unit. :cool:
johny_2000
Suburb of Seattle
My understanding is that similar results can be achieved using software EQ/PEQ in Win PC for any USB DAC. The only advantage of the built-in equalizer function is its independence from the source device. A sort of universal connection for PC, media streamer, smartphone, tablet, game console, etc. that can retain the same DAC EQ settings.
