User tracking ad platform now baked into Chrome browser
fpitas
Northern Virginia, USA
To its/their credit: MS Edge didn't pester me with ads on sites that now are, thanks to Chrome (even with AdBlock Plus).
Yeah, who thought that MS would ever have a good browser?
Blumlein 88
Blumlein 88
Well the current Edge browser is based upon Chrome. As are Brave, Vivaldi and many others. Firefox is not. I've been using Vivaldi some recently. It has some nice features and is fairly good on privacy.
fpitas
Yes, and my experience so far is good. Plus, I avoid the evil tentacles of Google.
audio_tony
Leeds, UK
I use uBlock origin as part of my defence against tracking etc.
I also run my own DNS servers at home, so I have setup DNS ad blocking as well.
For DNS blocking I use the lists from https://pgl.yoyo.org/adservers/
Blumlein 88
Blumlein 88
Because if there business model...
I use Brave when I run across the sites with some issue working with Firefox. Often medical/insurance sites in my particular experience. Not as common an issue with Firefox as once was the case. I may switch to Vivaldi for this, but I don't mind what Brave does anyway.
krumpol
SVK
I use fire Firefox and turned off as much as I could on Windows after reading a few guides on CNET and others.
Customizable user.js template by Arkenfox is perhaps the best one I found. All configurable Firefox parameters explained, including couple of hidden ones.
kysa
Such projects (Librewolf, Arkenfox) are, unfortunately, useless against tracking. See creep.js
pseudoid
Kinda funny [<< hilarious type] that we worry about the browsers sniffing us out but the 'tracking' problems start with the OperatingSystem...and don't you dare call it "telemetry"!
There is a simple task to slay the major "ET Call Home" features of WinOS:
Press the Win + I keys, select Privacy & Security, and Diagnostics & feedback under Windows permissions. Select OFF for all options on this screen and every other line-item in the Privacy & Security settings page. Then, follow-thru/stop logging in with a microsoft account and go local sign-in.
imo >> This is a good start.
pseudoid
The next 'silent' elephant has got to be ... NOT google and/or NOT internet trackers ... but your ISP.
Does your ISP really give a flying-guano about https? I think not!
imo >> How about selecting alternate DNS servers instead of the ISP assigned snoops?
Certainly I wouldn't suggest anyone to employ VPNs but truth be told they have grown up and near transparent anymore.
Sal1950
The Chicago Crusher
Central Fl
Brave here as well (Android phone and MacBook).
Brave is really only effective if you run behind a VPN.
I was just forced to disable my Adblock Plus on Youtube or be locked out :mad:
audio_tony
Leeds, UK
A VPN is largely a waste of time, unless you particularly need to access content that you are unable to access from your own country (TV streams etc.).
Claims that a VPN offers better privacy than a standard SSL connection to a website is a fallacy. Using websites with SSL enable is as secure, if not more so.
Some time ago, I did the following diagram to explain...
pseudoid
Why not suggest VPN use?
You mean like the other ideas aren't shabby to begin with?
The recommendation of VPN use is like a 6dB volume increase and borders on paranoia.
I rolled my eyes when someone suggested tor usage but I would not make fun of anyone that makes use of a VPN, when necessary [self included].;)
Blumlein 88
Blumlein 88
Rather like my thinking. Tor is over the top for normal use. A VPN may but a bit much, but only a bit. Of course many companies make employees use them working from home.
pseudoid
LoL!
I ran a 'relay node' (not an 'exit node') for aide in some int'l refugee/dissident eff activism... I started getting DMCA violation (17 U.S.C. § 512c) notifications from my ISP... The 'safe harbor' clause got me off the hook... until I gave up 9 months later... ever try using tor-over-vpn? A roulette-wheel but strictly for giggles!.
Blumlein 88
Blumlein 88
Yes, I always select DNS servers not using those from the ISP, and not from Google.
Blumlein 88
Blumlein 88
LoL!
I think I tried like a Tor browser over a VPN. It worked sometimes and sometimes never went anywhere. It was just to see what would happen.
