DualTriode
- Joined
- Oct 24, 2019
- Messages
- 904
- Likes
- 595
Hello All,
On the bench I have an APx555 and GRAS 45CA-9 headphone test fixture. Also sitting here is a Topping A30 Pro headphone amplifier.
The goal is to select cords and plugs to extend the amplifier outputs across the room or across the hall away from the noise of the APx555 cooling fan on the bench.
Also I am thinking of using the A30 Pro amplifier to test Compression Drivers and horns for TS/P’s impedance curves and similar.
For this handful of pure Watts I am considering using Canare 4S6 20AWG Star Quad speaker cable and NUTRIK 4-pin XLR plugs
Similar to what I am doing with the Benchmark AHB2 reference amplifier I will test an assortment of cords and resistors to confirm the best performance of the A30 Pro.
Then armed with known quality test leads the tests of headphones will be a go.
Thanks DT
@JohnYang , do you have a idea of a quality output extension cord for the A30 Pro headphone amplifier?
Thanks DT
