My current setup is a Rega Planar 3/yellow Exact cart, Rega Fono MM Mk3, Rega Brio, Monitor Audio Silver 300. I also use a cheapo WiiM Streamer for the rare times I stream (this is slated to be replaced with a Cambridge CXN V2 next year).
I've decided that my next step in building my home stereo outfit is going to be a tube amp. I had selected a Rogue Cronus Magnum III as a nice starting point, but I'm having trouble pulling the pin on a 5 grand Cdn unit when I'm just not sure if I'll enjoy it or not. I've listened to several tube amps over the last couple months, loved the sound, but none at home with my setup in my room.
I keep eyeing up a Willsenton R8, and I'm wondering if this unit would indeed give me a proper taste of tube amplification and allow me to decide whether I'm going further down that rabbit hole, or if I should be upgrading my turntable instead. I've tried to find direct comparisons online, but haven't had much luck. Anyone on here had a Willsenton and then switched to higher end unit like the Rogue or a Linn? Does the Willsenton really give good enough results to tell someone if they want tube amplification?
Thanks in advance for any opinions and advice.
Rod
Rod
