wav test?
morillon
Hello
I'm looking for some wav files to perform some measurements on wifi streamers...
1k: 44k 16bit and 24bit, 48k 24bit, 96k 24bit
multitones as you use them around here for your dac tests?
Any ideas for sites where to find them?
not
thank you
morillon
morillon
thank you
i imagine that 44k 16bits ...for cd
morillon
morillon
i dont know the use of this software
kchap
Melbourne, Oz
Sound eXchange. It's a very versatile command line based tool for converting file formats, sample rate and bit depth, generating test signals, adjusting gain etc.
I use mainly as part of the process of ripping my CD's. I also dabble. Google is your friend. I entered into the search: generate multitone signal using sox
This was the first match: ASR SoX. The PDF that comes with SoX is a bit overwhelming for the novice but it is really quiet good. I would read parts of it, become a bit confused and then search on the web for examples. I would compare the examples with the PDF and slowly start to make sense of it.
If do not want to try SoX there will be others tools out there. I'm just not familiar with them.
staticV3
You can generate all kinds of test tones using the signal generator inside REW.
The program is free to use and works on Windows, macOS, and Linux.
morillon
morillon
i can generate a wav file? ( i need a wav only that for transfert easy to the streamer.....)
i use a lot rew ..but for only mesureameants loudspeakers with sweep etc
morillon
morillon
thank you!
I look a bit silly
DVDdoug
Audacity can also generate & mix tones. First you set the sample rate ("Project Rate") then it's just Generate -> Tone -> Sine, and select the amplitude and frequency.
And you can simplify things by starting with a high sample rate, save ("Export") then lower the sample rate, export again, and repeat, etc.
I'm not exactly how the multitone tests are done but if you have two or more tracks open in Audacity they will mix when you play or export. But, since mixing is done by summation you have to watch the levels to prevent clipping.
morillon
morillon
that s for toslink 0db
thank you !! that s top and so easy!!
i just dont know of i need "add dither" or not...(???)
RayDunzl
Central Scrutinizer
Riverview FL
dualazmak
Just for your reference, I recently posted this message on a remote thread...
morillon
morillon
thank you !
I will study that...
for now, rew once again impresses me
morillon
morillon
me again ;-)
jtest sine etc no worries to generate appropriate wav with rew...
but if offers a possibility of "multitones" ... I don't know how to make a multitone32 or 64 as it seems to be customary to use around here?
Any idea of the settings needed?
thank you
(too bad that "multitone "does not allow to produce wav ;-) )
morillon
morillon
a test with a wav from the generator rew in wiim (pretty big jitter)...64k,"white", decade1/10 toslink 96k24bits...... but does not really correspond to what seems to be in use here said "ap" audioprecision:(
an idea? or multitone 100?
BeerBear
RMAA can also generate and then analyze a test signal. They both have to be the same sample rate, though.
