I tried a few of the budget usual suspects that you usually find in amazon a 1-2 years ago (mii eksa avantree...). Always bad results, sound drops... nothing worked as well as a regular smart phone in my experience. I think the spdif inputs where the problem. In any case, this made me decide to abandon Bluetooth for home use and go all in with wifi. My 2cents.I've discovered this thread because I'm in a similar situation, I'm looking for a Bluetooth transmitter/receiver for desktop, yes because I want to pair my Qudelix 5k with it and make my headphones wireless
My PC>Bluetooth Transmitter>Qudelix 5k>Headphones/Speakers
I find dac/amps which have Bluetooth connection but only RECEIVE, so is there a good Bluetooth transmitter with a good price and performance? Especially with LDAC codec
I have had a similar experience with Bluetooth. How did you go about going with Wifi?I tried a few of the budget usual suspects that you usually find in amazon a 1-2 years ago (mii eksa avantree...). Always bad results, sound drops... nothing worked as well as a regular smart phone in my experience. I think the spdif inputs where the problem. In any case, this made me decide to abandon Bluetooth for home use and go all in with wifi. My 2cents.
I stream the sources (currently only my turntable) with LMS to my other pi based streamers or phone.I have had a similar experience with Bluetooth. How did you go about going with Wifi?
The newer version, the BTA30 Pro supports LDAC transmission on transmit from USB & SPDIF. bta30proThe FiiO BTA30 will transmit over Bluetooth using LDAC. Although I think there are some limitations on the inputs you can re-transmit over bluetooth.
*edit* Yeah, it won't retransmit USB input (which makes it a bit of a 'chocolate teapot' IMHO)... https://www.fiio.com/newsinfo/454064.html
If you don't have SPDIF/Toslink output on your PC, and you're comfortable rooting around inside it, then it's pretty easy to add a SPDIF/Toslink output with an add-in card (you'll need the motherboard manual to locate the SPDIF header on it)...
Here's the one I used to solve a ground loop issue with TOSLINK (before I bought a balanced DAC)...
I should add that the SPDIF header on the motherboard is likely to only have 2 pins, you'll need to power the adapter (+5V pin) from another header on the motherboard (+5V on a spare USB header will do the trick).
It has more flexibility on input selection than the BTA30 did.
Hi,
Not sure this is right place to post this... If so, please feel free to move this post.
Here is what it is about.
I am connecting my headphones to my computer via Bluetooth.
To do that I use an ASUS BT-400 USB Dongle (this is a desktop and the motherboard is a workstation motherboard so has no integrated BT or Wi-Fi).
Visiting the Amazon website, I see a lot of products called "USB emitters" (here's an example : Bluettoth emitter).
My question is quite simple : I will drive an aptx-hd enabled Bluettoth headphone.
Will these thing show a benefit (metter signal, nojerky sound, no interference with other BT devices...) over the ASUS BT-400 ?
They're not super cheap but reamin mostly affordable (40 to 70 dollars)...
So I was wondering if they will do any good and if anyone has experience/recommandation...
Thanks a lot for your answers
Regards.
I'm waiting to upgrade to LDAC.
That is why I am waiting. I haven't seen an implementation that will work for me (yet! [But I am hopeful])I would not assume that LDAC would work or sound any better at extreme range. It's certainly going to step the connection down to the lowest bitrate and may have difficulty maintaining the connection, regardless of the bitrate.
I am waiting to finish renovating my other (new to us) house (only 1.3 miles from work) which will have the computer room next to the audio/video/living room. Since the rooms are smaller & only have 8 Ft. ceilings (as opposed to cathedral ceilings), everything is going to change, likely for the worse (except for the distance between the computer & the stereo), which will be less than 1/2 of what it is now. The renovation cannot be completed without my wife's input & she is currently overseas. Hopefully she will be back by the end of March. In the meantime I have taken down 4 major, dangerous trees (one was beating the house in high winds, a second one was almost at that point, 2 others had destroyed the driveway from opposite sides of the driveway, I installed a new 2 & 1/2 ton gas-pack heat/AC, all new duct work, registers & return & new gas lines. Next is all new electrical lines & outlets & then rip out the 2 bathrooms and level the 1968 home. When she gets back we'll tackle installing new bathrooms, new kitchen/dining room & then my parts of what I want for our house.You'll be waiting for the laws of physics to change. Bluetooth is designed and optimized for relatively short range, low power & bandwidth applications. A streamer with wi-fi support would be more appropriate for your use case.
I am waiting to finish renovating my other (new to us) house (only 1.3 miles from work) which will have the computer room next to the audio/video/living room. Since the rooms are smaller & only have 8 Ft. ceilings (as opposed to cathedral ceilings), everything is going to change, likely for the worse (except for the distance between the computer & the stereo), which will be less than 1/2 of what it is now. The renovation cannot be completed without my wife's input & she is currently overseas. Hopefully she will be back by the end of March. In the meantime I have taken down 4 major, dangerous trees (one was beating the house in high winds, a second one was almost at that point, 2 others had destroyed the driveway from opposite sides of the driveway, I installed a new 2 & 1/2 ton gas-pack heat/AC, all new duct work, registers & return & new gas lines. Next is all new electrical lines & outlets & then rip out the 2 bathrooms and level the 1968 home. When she gets back we'll tackle installing new bathrooms, new kitchen/dining room & then my parts of what I want for our house. She has done the renovating of our 2 previous places. I am now realizing what she went through to get them to the point that I only had to hook up the washer & dryer & we were done.
The FiiO Control app lets you choose (via) whether to optimize LDAC for audio quality or range and the antenna might indicate a good signal, so I guess it's worth a try.
