what are your industrial design favorites?
Harmonie
France
Or it's Barbie version :p
Blumlein 88
... and I've dissolved tile floors in a biochemistry lab (or two).
Yeah, I thought tile was better. If a spill dissolves a square or three you just replace them. Worked in one that had that resin coating over the whole floor and curved up 3 inches along the edges. That was pretty cool.
fløyen
Central NZ
Team New Zealand launch their second AC75. Photo / Supplied/Team New Zealand
fløyen
Central NZ
The ‘Return to Sender’ mission, which will be Rocket Lab’s 16th Electron launch, will lift-off from Launch Complex 1 on New Zealand’s Māhia Peninsula.
Rocket Lab’s Electron launch vehicle will loft 30 satellites to a sun-synchronous orbit at 500 km altitude for a range of customers, including TriSept, Unseenlabs, Swarm, Auckland Programme for Space Systems, and global gaming software company Valve. The satellites span a range of operations, from TriSept’s tech demonstration of new tether systems designed to accelerate spacecraft reentry and reduce orbital debris, through to the next generation of maritime surveillance satellites for Unseenlabs, as well as communications satellites for Swarm.
Dmitri
I like the heatsinks on this one. I'm not sure the whole visual design hold together, though.
Actually, it kind of looks like it’s falling apart. Someone on the design team must play the accordion.
Wes
ok, I call bad design
the sides would make better heat sinks
Feanor
southwestern Ontario
