I’ll be your personal Google assistant:... apart from making record companies more money by reselling the same thing over and over again.
Serious question, I really don't know the answer.
Which says nothing apart from "polishing." What is polishing, and why does it need to be done again?I’ll be your personal Google assistant:
You’re welcome
I'd have preferred it if they they had reduced it by a note for each remaster. There'd be nothing left by now. But tastes differ...I remember the first CD release of Led Zeppelin I had half of the first note of every song missing. Each track was effectively joined in process.
The remaster corrected that.
Confirmed in what way?The new remasters often sound more detailed. It's not dynamic range compression, although there is often plenty of that too. I used to be ambivalent about original CDs or remastered CDs, but have confirmed digital remastering sounds better sometimes.
Good question. When I got a studio-quality audio interface and headphones. CDs copied perfectly to a computer, the same audio data as on the CD.Confirmed in what way?
Speaking about the remastering process, Andy said: “Remastering and the use of ‘state of the art’ technology allows us to polish and remove the gremlins of both time and the recording medium such as analogue tape.Which says nothing apart from "polishing." What is polishing, and why does it need to be done again?
So they keep the magic but add their own wizardry?Speaking about the remastering process, Andy said: “Remastering and the use of ‘state of the art’ technology allows us to polish and remove the gremlins of both time and the recording medium such as analogue tape.
“We can reduce background noise and hum, enhance and expand frequencies, improve analogue tape edits, remove unwanted electrical clicks and other extraneous unwanted noises - as well as better capture, at a much higher resolution, the magic of the original recording to any medium.
I found the article I linked very succinct in answering your question. Specifically regarding “polishing” I read it as the removal of unwanted noise in the original mixes, something that wasn’t done when first mastered as the technology of the time didn’t allow it. So it’s not that it needs to be done again, just done.
I think most remasters are to revisit EQ and compression. They are artistic as well as practical modifications. But most of all, they are for profit, based on the promise of better sound.So they keep the magic but add their own wizardry?
Do they have fairy dust in their cables too?
I've listened to many remasters where obvious technical errors remain, and none where they don't.
Ah. Back to my original point then. No need to google that!I think most remasters are to revisit EQ and compression. They are artistic as well as practical modifications. But most of all, they are for profit, based on the promise of better sound.
Remasters work with a stereo mix, so the only tools are EQ, compression/limiting and noise reduction. There's no remixing. That would be a remix, which are out there (search Steve Wilson remix) and they definitely make a difference. As far as remasters, if there to "fix" something fine but most just change some EQ and add compression and are usually a waste of time. And I don't get why people need 4 versions of the same music thats almost identical.LoL... It tunes up old yucky versions of songs so they can be re-released and clog up the music web sites with their rubbish... I imagine they remix the various instruments and singers voices and try to find some more interesting arrangement in the final cut of the track release.
