What is the best value for money/cheapest DAC which measures well? £ for £ / $ for $ and lowest cost.
Westsounds
The Topping D90SE is the king of the list as far as I can see but value for money, does anyone know off the top of their head just from studying the test results which DAC in the results list gives the ultimate performance per cost?
And is there a DAC under £40 for instance that can get near the higher end well designed and measuring well DACs but do it at a much lower cost?
Willem
What kind of input(s) and do you want a volume control with it?
bogi
Slovakia
The question is what is for you enough good. It may mean something different for you and for me.
For me Topping E50 is price/value king. I don't listen to graphs and I don't belong to "all DACs sounds the same" local initiative.
W
Westsounds
Yes but if they are doing their job right they should all be doing the same thing. Once all the 0s and 1s are converted as they should be all dacs shouldnt be a million miles away from each other. The rest is perhaps the components colouring, changing or adding to the sound. And tonality is a personal preference.
NiagaraPete
Apple dongle $10.00
NiagaraPete
W
Westsounds
Thats interesting actually. I don't have a apple phone though
Ninjastar
Nothing just a basic dac, optical toslink and coax that's it.
Schiit Modi 3+ maybe?
SMc
Check out the review index! The cheapest recommended DAC doesn't measure well but costs next to nothing. Not $4 anymore but still under $15 for something that functions:
Check out the dongles if your computer is your source.
bogi
Slovakia
That's not so easy. Each delta sigma DAC contains delta sigma modulator. That modulation (which also occurs in the case of PCM to DSD conversion) is not a bitperfect reversible operation and can be of different quality. When you convert PCM to DSD and then back ot PCM, you never get the same file again. Not so easy. Similarly, digital interpolation filters of a DAC can be of a different quality. Then the D/A conversion stage itself, which is in principle a low pass filter, do you think there is only one 'ideal' implementation? If yes, show it us. And then there is level of noise rejection mainly from digital inputs and power source, this topic is beyond the capabilities of the "all DACs sound the same" local initiative.
krabapple
Demonstrating the existence of convincing and routinely-occurring audible differences in normal listening situations, seems to be beyond the capabilities of DACophiles.
Snarfie
Netherlands
JSmith
Algol Perseus
Should be less that 80 pounds over your way.
JSmith
NiagaraPete
Don’t need an Apple device to use it. As long as your device has a USB-C port, it should generally just work.
Or Lightning port
Atanasi
This probably works if you use USB. I am worried about the S/PDIF reliability of post-AKM Topping DACs.
