What Measurements Show These Things?
RayDunzl
Central Scrutinizer
Riverview FL
If the speed of electrons is a concern, they should use the smallest diameter conductors they can find,
Robert394
I was just going to post something long these lines and would be interested in an answer also.
Is there a measurement for:
-Sound stage depth
-Sound stage width
-Harshness
I think most/many people who have listened to speakers will have observed differences in the above characteristics between speaker systems... can they be measured though?
RayDunzl
Central Scrutinizer
Riverview FL
I just need to know how many more veils I need to lift.
audio2design
I will take full power frequency response for $100 Alex. I will pass on the "complicated ham sandwich" bonus.
Real audio, not test signals, is bandwidth limited. Square waves, slew rate, etc. complicated ham sandwich measurements. Mathematically its a bunch of sine waves, and they don't have infinite bandwidth, 20KHz, pretty much. Even if the source supports > 20Khz, you will find there is never full power harmonics at those frequencies.
gsp1971
Europe
What measurement shows whether an amp has 'glorious midrange tonality' but 'slightly plasticky treble' ?
sergeauckland
Suffolk UK
Some years ago, there was a fashion for very thin 'speaker cables, and I remember asking one salesman how they could possibly work. His reply was that the cables are so thin, there's nothing to stop the electrons...
:facepalm:
S.
pozz
Слава Україні
Editor
:facepalm:
S.
I found the source book for this idea at one point. Can't remember the title or the author though.
pozz
Слава Україні
Editor
-Sound stage depth
-Sound stage width
-Harshness
These are a combo of room acoustics and speaker radiation pattern. At least at this point it can't be predicted for home listening. If you're building a room from scratch, or a concert hall (or adding complex reinforcement), there is some ability to infer what will happen. It requires detailed measurements of room and speakers.
Blaspheme
Officially by last count, the answer is 23.
For a subjectivist, the answer is asymptotic. For an objectivist, the answer is SINAD. For a classicist, the answer is 7. For an antivist, the answer is K-pop.
