I want to test the harmonic distortion and noise floor produced by different audio interface when recording, but I have many questions:
1. What is the difference between the microphone signal and the line out signal? Is the THD+N measured by connecting the line out to the mic interface useful for the actual use of the microphone?
2. Does turning the 48V switch on vs off make a huge difference on THD?
3. When the 48V is not turned on, is the noise floor and harmonic distortion generated by different gears of gain (for example: 0dB, 30dB, 62dB) the same in the line in state as in the 48V mic in state?
4. If I use another DAC to send a 1KHz sine wave to the ADC, is there anything else I need to be aware of? (e.g. will turning on 48V burn the device)
