Which DAC measurements do you like to see next?
Veri
tential
You don't need to worry about that in this context. I am commenting on it advertising high-resolution support but is something that I can't easily test on Windows. Oddly on MacOs it supports 24 bit.
The reason I ask is that from some posts I've read here, it's sounds like a dac has a max Snr, but is capped by the source file fed to it? Correct me if I'm wrong.
RayDunzl
Central Scrutinizer
Riverview FL
Where do you recommend I read up on to understand more about 16bit vs 24bit and how it effects dynamic range
Full-scale 16 or 24 bit recordings come out of the DAC at the same maximum electrical level.
Cynical Opinion:
The practical difference in dynamic range occurs by dividing the smallest bit of 16bit into 256 more levels of inaudibility.
digicidal
Sin City, NV
I think you just quantified 'the veil' - which I'm afraid of lifting inadvertently... hence it's strictly 16/44 for me. Of course, I like a lot of ugly music so that could be a factor.
frogmeat69
Western New York, USA
scott wurcer
Audio Luminary
Focusrite Scarlett Solo Gen3 (or any other Scarlett Gen3)
That's funny about 5min ago I went looking for this thread because I saw some very good plots from a 2i2 Gen3. Even funnier about 15min ago I was watching the Tonight Show episode where Johnny Carson debunked Uri Geller the psychic.
solderdude
The Neitherlands
THIS ONE please.
I am sure the manufacturer will gladly send you a sample.
daftcombo
I would like to see one day the measurement of the DAC of some famous old CD Player, let's say Phillips CD 723 or Marantz CD 6003, just to know how capable those machines, so popular, were. It would also be nice to have a measurement of their coaxial out.
