WHICH DAC SETUP?
ToKillTime
Hi guys,
currently, I am using a RPI4 with the HiFiBerry DAC+ Pro as a network player, which supplies my amplifier (Rotel RA 1592) with content (Line out).
Since the Rotel has an integrated DAC (AKM Premium 32-Bit/768kHz), I wonder if the following alternatives would be more suitable?
1. RPI4 > HiFiBerry Digi Pro > SPDIF > Rotel
2. RPI > USB > Rotel
Does anyone have experience and can give me a recommendation?
Thank you in advance!
Cheers,
ToKillTime
AnalogSteph
.de
Assuming the Rotel's USB shows up as a UAC2 device (XMOS or similar), I would try to use that. It seems to be using an AK4495, a noticeably fancier part than the PCM5102 (I think) that the HifiBerry uses. Realistically, either should be more than good enough, but at least you'd have banished one analog connection that may be subject to ground loops.
Jim Matthews
Taxachusetts
This. Lower box count, where possible.
