I absolutely understand the allure of vintage recivers, BUT the top models, the most sought after with a lot of power are, to say the least, in my eyes quite expensive. That compares with how many nice clean watts you can get at a reasonable price today if you buy a new modern amplifier.
Aesthetically, the looks, okay there vintage (in my eyes) has the upper hand. But why not combine the best of both worlds? For example, take one:
Yamaha CR-600. A 30 W receiver. I think it looks good.
Combine Yamaha CR-600 with a modern class D amp that drives some subwoofer / bass modules. Divide the signal via miniDSP. If possible (considering, regarding, ventilation, cabling) throw the ugly class D amplifier in a cupboard or closet. With HP-LP filter and let the Yamaha CR-600 work from 80-100 Hz
and upwards (relieve it by working with the subwoofer frequencies) and together with suitable speakers, with sufficiently high sensitivity so ....hm for most it would work great as the main HiFi solution.
But it boils, as usual, down on the speakers where the most money gunpowder is to be put.
Here, see attached picture # 45 in the thread, measurement on Yamaha CR-600. A CR-600 does not cost astronomical sums.
Old ones measure very badly indeed by today's standards (check out 80's HiFi Choice measurements, IMD is dire for exampe), but the current cosmetic models I'm seen tested in Stereophile do seen 15 - 20dB better in distortion figures, albeit using different test gear of course and I think that as...
audiosciencereview.com
The same setup can of course also be something for tube enthusiasts to consider. Let a modern class D amp take care of the lowest frequencies.
MiniDSP also provides the option of EQ, which still, at least for subwoofers, is always needed if you want to get a decent sound.
This is, appearance yes ugly, but affordable:
This is a review and detailed measurements of the thomann t.racks DSP four by four matrix DSP. It was kindly purchased new by a member and costs just US $99. I really like the form factor here and inclusion of brackets for mounting in cars and such. Inclusion of balanced I/O is much...
Not stylish but effective, powerful:
This is a review and detailed measurements of the Behringer A800 Class D Stereo Amplifier. It is on kind loan from a member. The A800 costs US $299 including free shipping from multiple sites. The member who loaned it me has done a youtube video of it which you can see by clicking on this...
Edit:
Or if you do not want to bother about it. Yamaha CR-600 in the hobby room, the bedroom. Only modern HIFI stuff in the main HiFi solution. There are many different ways to combine new and old.
I know it can be a bit tricky if you use more than one source, for example streamed with the solution above, but then use a vintage receiver as a pre amp. For example HK 330B, see attached picture....Saw now that Yamaha seems to have pre out. Missed it, see attached picture.
(by the way if their preformance, said receiver's, regardning level of distortion + noise is low enough is mostly a matter of taste)
Only creativity sets the limits.
