- Joined
- Jan 15, 2020
- Messages
- 6,905
- Likes
- 16,970
Could you please explain those two points?There is some minor advantages with passive driven tweeters, and that is the opportunity to :
1. Less thermal compression if you use a resistor before the tweeter.
2. Less distortion.
By the way with high tech active designs you can also monitor the voice coil temperature and compensate thermal compression
https://www.tonmeister.ca/wordpress/2014/01/16/bo-tech-thermal-compression-compensation/
