Why not review some Hegel amps?
  • Thread starter Deleted member 18434
  • Start date
Objectivist01
I have a feeling that like many hyped products this can also have some issues. Until measurements are in, I won't interested in them
Matias
São Paulo, Brazil
amper42
Matias
São Paulo, Brazil
Has anyone actually measured the "VTV AMPLIFIER Purifi Eigentakt Stereo Amplifier based on EVAL-1" to verify it's measurements are the same as the original Purifi EVAL-1 that amir tested? Thanks!
Not the actual VTV version, but VTV uses the same power supply, buffer board and modules as the demo unit, it only changes chassis, cables and connectors, so I would say it is almost identical.
Darkscience
The Benchmark amp is outstanding but in the design department they could really take some lessons from Hegel.
I love the look of the AHB2 and do not like the look of Hegel. Pictures do not do the AHB2 justice. The AHB2 looks like it came out of a Star Wars movie, really cool looking piece of gear. Hegel looks cheap to me.
amper42
My Hegel H90 is nothing great to look at. However, it makes my BMR's sing clean and clear.
I connected the 400W Purifi based March Audio P452 amp to the BMR's thinking it would take them to a new level. After A/B ing the setup I preferred the 60W Hegel H90 amp to the 400W Purifi. Not sure why that is, but I'm amazed how great the little Hegel 60W amp can make the BMRs sound.
steve59
I listened to several including a parasound a21 krell kav 300il an anthem 225i a rgr model 5 a h360 a rost and h190. I bought the 360 for the big power but the rost and 190 really brought up the treble of the revel salons. The bass control of the h360 is real and audible.
mcdonalk
Any review of an amp (or any audio product, for that matter) should address, not only its audio quality, but its functionality. How well does it work? I bought an H390 but regretfully had to return it within the audition period, because of audible transient sounds ("pops") when starting playing of DSD64 and DSD128 files. I just could not ignore this anomaly for a product that was so expensive. Interestingly, DSD256 playback worked fine.
Should you be interested in the details, I posted them here some weeks ago:
https://www.audioshark.org/hegel-179/h390-dsd-dop-pop-19704.html
steve59
Any audible pops would be unsettling for sure, I have an old B&K 4420 amp that when switched off unloads( surely describing wrong) the power into the speakers resulting in the woofers thumping...
Matias
São Paulo, Brazil
DACs_Lover
There is a review of the H360 in the Polish site (here). Eyeballing the THD+N over power it seems to have a SINAD of under 80dB with a 4 Ohm load.
HI there. Could you explain please how to get a SINAD value from THD+N
Thank you.
Rizzle
@DACs_Lover the easiest way is to use a tool online, you basically translate THD+N % to dB. The formula they use use only says THD but just fill in THD+N % then you'll get SINAD. You only need it to go from a percentage to decibel value.
http://www.sengpielaudio.com/calculator-thd.htm
Or use the formula: 20*log(THD+N %)
/Edit: Using an example of the Sonance DSP 2-150 just measured by Amir, you get:
Channel 1's THD+N = 0,017479%
20*log(0,017479%)
Which correlates with:
MCH
Hey Amper,
I am also quite happy with my H90, i find it very convenient to have streamer/DAC/amp in one minimalistic relatively small box and i am in general very happy with the sound. However...
How do you find the headphone amp? i find mine unusable, it is super noisy (independent of volume) and specially with my K371 it is useless for me. On top of that, when i connect my topping L30 to the pre-out, presicely to avoid the noisy headphone out, the signal from the pre out is so weak (at max volume of course) that the L30 struggles to give a decent volume (still ok with the K371 but with the HD600 i must set the L30 to high gain and the volume at 3 oclock to get a decent volume).
I am curious to know, specially regarding the noisy headphone out, if my unit is broken or if it is what it is, your comments will be greatly welcome! thanks!!
amper42
Hey Amper,
Sorry, I have not tried the Hegel H90 with headphones and I have to agree the pre-outs on the Hegel seem weak. I also notice the wifi connection on the Hegel H90 is relatively poor so I use the USB input to connect the computer and that works absolutely great.
I tried connecting the Hegel H90 to the Revel F328Be instead of my BMRs. It was a disaster. In this case, the Purifi amp provided an abundance of power while the Hegel H90 would distort at relatively low volume levels. It wasn't pretty. The longer I own the H90 the more I understand it's short comings (wifi/pre-outs). It may not work well with larger speakers. But if you find a good speaker match while using the USB input it can sing.
Reactions: MCH
