Windows Foobar2000 to Linux Playback Software Advice
levimax
San Diego
Hello, my Windows based music system motherboard just died and since I had to get a new MB I also jumped ahead a couple of generations on CPU. This change is forcing me to decide if I want to pay the "Windows tax" or go with Linux. While I don't particularly like Windows I am a very happy user of Foobar2000 and several key plugins. The convolution plugin (I use convolution for speaker/ room EQ as well as RIAA EQ). The "Resampler-V" plug in is used to convert all my different sources to the same bit depth and sample rate so my convolution filters work with all sources. Finally I use the "recorder" plug in to add DSP to my TT (through an ADC) and Qobuz playback. Is there a player that does all this or a player and additional programs that can do it all in Linux? I have compiled Linux from source in the past so not expecting plug and play although I wouldn't mind. Thanks in advance for any advice.
Sokel
Isn't the Mac versions work on Linux?
Foober has a Mac and Android version too.
