WTB: Budget headphone amplifier
Rayman30
Looking for something decent and a low price.
FOUND, thanks to everyone who replied.
Dunring
Florida
It depends on the budget and headphones you need them for, but there's some in the 100 range you can't go wrong with. The Schiit Magni Hersesy or JDS Atom amps are terrific. On eBay or Mercari they can be found for $80 plus shipping usually, or $99 plus shipping new direct.
solderdude
The Neitherlands
What Budget.
What needs to be driven (power/imp range)
What must be decent ? Performance (and what do you consider decent), longevity, functionality (gain, power, connectivity), size (it matters)
Rayman30
Rayman30
S
What Budget.
$50-$100
LCD-X, LCD-2 Closed, Focal Clear MG, HD650
Good power, can’t be Schiit (They keep failing on me)
SE connection is fine, the more power the better, preferably >1W @32 Ohms
Eye balling liquid spark on eBay. This is for the living room so its not super high priority.
solderdude
The Neitherlands
S
$50-$100
That doesn't leave many options other than some Chinese offerings or maybe JDS labs or some second hand stuff.
Rayman30
Rayman30
Seems like springing for a Topping L30 ii would be worth the extra money
Edit: Found a Liquid Spark for $75 on eBay. Thanks though!
cubanmetalguy
Miami, Florida, USA
SMSL SH-6 Mini Desktop Amp is a great little amp.
odarg64
What makes it "Hi-Res Audio Certifed?"
Classic toggle switches as a feature... :facepalm:
FrantzM
Can't see the forest for the trees? Sometimes one needs to brush off the marketing-talks...
This is a superb amplifier if we are to believe SMSL specs, which have been close to tested//reviews. it should be capable of driving most headphones:
  • 2.6W x2 16Ω
  • 1.3W x2 32Ω
is plentiful power and at <$110!! Actually, any price.
Another recommendation. I recently bought new open box, on eBay, a THX AAA789 at $150.oo. A superlative amp. At that price, a no-brainer, it is comfortably driving the amp-killer, HifiMan HE6-SEv2...
Peace
