Xduoo Link2 Bal: the most powerful USB dongle DAC-AMP on the market?
Madlop26
This little toy was just released last month, and I pulled the trigger, $149, it claims to have an output power of 270mW@32ohm from its 4.4mm balanced output.
My main reason to get it:
It has a a 4.4 mm output which is uncommon in small dongles, and many on my headphones are 4.4 mm, but also it has a iPhone connector which works without the need of the usual Lightning to USB Camera Adapter, so for iPhone users potential safe of $30 dollars
This little thing drives all my headphones above comfortable listening volume, but when listening to my Dan Clark Aeon RT, I decided to go to top volume, was very very loud but then suddenly it shut down, probably safety mode or iPhone could not give all the power needed?, anyway, i did not try again, i don't want to break the thing
I wonder if any of you guys got it and what is your opinion.
d2k5000
Looks interesting. I have been looking a portable dac/amp solution for harder to drive full sized headphones. I would certainly be interested in seeing it measured.
d2k5000
Just looked up the review for the xDuoo XA-10 amp, and it certainly performed much worse than the specs sheet would have suggested. I can only hope that the Link2 Bal would fair better.
LakeOfThaWyld
I suspect your probably right about power overload, iPhones have limited power draw. L7 Labs already measured the Link2 Bal, seems to be a bit of a mixed bag. Great DR, but has a couple other issues. The W2 131 uses the same chip, but measures much better (especially at higher volumes). I’m not spending $300 on a dongle. I’m considering the Link2 Bal though, I tend to like the xduoo house sound even if there’s some distortion.
A battery powered DAC/amp is a bit more cumbersome, but it side steps the iOS power issues.
The #donglemadness guy just put the Link2 Bal in his current top 5 for what it’s worth.
M
Madlop26
Thanks for the links! very informative. The W2 131 looks cool, you avoid the multitone bug, additional SPDIF output, little screen, some filters and EQs; but double the cost......decisions..decisions...
tifune
E1DA 9038S has about the same output and better distortion at a much lower price
M
Madlop26
These are the manufacture claimed specifications:
E1DA 9038S
180 mW @32 Ω
Xduoo Link2 Bal
270mW@32Ω
yeah, they are not true
Amir got only 155 mW @ 33 and 20 mW @ 300 on the E1DA 9038S
I found head-fi measured the Xduoo Link2 Bal at 180mW@33, which was disappointing but still better than the E1DA 9038S
also showed 130mW @100 , I could not find measurement at 300
I also have the Hidizs S9, Amir got 110 @ 33 and 52 @ 300, so kind of better for high impedance headphones if you compare with the E1DA 9038S
staticV3
E1DA 9038S
180 mW @32 Ω
You're quoting the 9038D there, not the S.
9038S official specs are:
>340mW@32Ohm@1kHz@THD=1%
>550mW@16Ohm@1kHz@THD=1%
My own 9038S G1 does 330mW@32Ω@1% THD+N rising to 620mW@16Ω@1% THD+N
Screenshot_20220223-135805_Sheets.jpgScreenshot_20220223-140203_Sheets.jpgE1DA_9038S_G1_Output_Voltage_vs_THDN_vs_Load-1 (1).png
M
Madlop26
View attachment 190027View attachment 190028View attachment 190029
my bad, I did not realize there were newer models, certainly the measurements are quite impressive. It seems at 100
ohm the Link2 catch up in power, anyway it seems the 9038D new Gens are best option for power dongles. My hidizz going for retirement , thanks!
JanesJr1
MA
Another option is the Hidizs S9 Pro, which Staticv3 indicated in another post is 25% louder than the 9038s. I have both. I use the S9 Pro constantly in balanced mode with both the Aeon Closed X and Noire (both high current/low impedance loads) with excellent results. (You must have an older Hidizs S9 or another model, not the S9 Pro?)
You'd need balanced cables. I got some good ones with the DCA Hirose connectors from Hart Cables, at a reasonable price as these things go, and like 'em. I know it's an extra expense, but I use the Hidizs so much and it has worked so well that I count my blessings in being able to tote my DCA headphones around with me daily.
It may be just something about my setup, but my 9038s does shut down on me randomly and not all that infrequently when driving my DCA 'phones, although when it works, it sounds good.
[Edit: PS I just noticed your prior post was some months ago, so sorry for the late reply.]
