Couldn't it be disguised as a box of heavy chocolates?Hehe, that attracts tax/import duty as well
I once tried to ship a box of chocolate overseas and UPS refused to accept it saying it is usually used to disguise illegal drugs or something!Couldn't it be disguised as a box of heavy chocolates?
No. B&O shows the same in their datasheet:BTW, there seems to be higher freq. response peaking with 4ohm load than with 8ohm load and this is strange. Aren't the 4 and 8 ohm plots swapped?
As I see the usual PSU delivered with that amp is 32V and 5A. The XTZ will be significantly more powerful that that, even when you use a 48V PSU.
I'm from the Netherlands but the DIY kits are being sold on a Belgian website and I have had it build at Audiophonics in France. Best purchase I've made so far so I'd do it again but I could literally ride my bike to Hypex headquarters but can't buy it here.Yes it was disappointing. It seems that Aiyima a07 shows better measurements than this XTZ in some ways.
Fun to finally see a review with measurements of this unit, shoutouts to the member who sent it to Amir!
A bit disappointing results, I have two of these units and have been very happy with their performance - especially given the price.
With regards to power levels, I think XTZ suggests the gain control can be used as a max volume limiter. Could we perhaps expect it to reach the rated 300W if the gain was increased? Where was the gain level at when tested at 29dB gain? (1/2, 3/4 of max?)
That's sort of my plan, feeding E30 with Chromecast Audio Optical and stream everything across, I just need a decent power amp, Hypex or might be one of the future Topping ones.Looking at reviews such as this, I wonder if I would be better served, for a music listening setup (with a PC as the source) by getting a Topping E30 and something such as a recently serviced Adcom GFA-545 II. This would give me remote control volume with the E30 in preamp mode and probably a lovely sounding setup. I just keep hoping for a new amp in this price range to reach the performance levels of recent headphone amps.
KJF Audio are doing mono and stereo amps now, as well as the original multichannel one. More expensive than Audiophonics, but more choice on front panel and connectors.I did consider Nord, they don't build amps based on NC122MP like Audiophonics plus they are expensive
I shall take a look, thanksKJF Audio are doing mono and stereo amps now, as well as the original multichannel one. More expensive than Audiophonics, but more choice on front panel and connectors.
Take a look at @Buckeye Amps here on ASR. He's a member and building amps for a VERY good price.That's sort of my plan, feeding E30 with Chromecast Audio Optical and stream everything across, I just need a decent power amp, Hypex or might be one of the future Topping ones.
I am based in the UK, it's not viableTake a look at @Buckeye Amps here on ASR. He's a member and building amps for a VERY good price.
You must think I'm daft-I didn't realize you were the fellow I suggested this to earlier-I wanted to package it as a box of chocolates...have you considered just putting one together on your own? Buy a kit from Ghent (case and wiring) and a module and viola! It's not terribly daunting and far cheaper than buying one already assembled.I am based in the UK, it's not viable
I did consider but I can't get hold of NC252MP or NC122MP. NC400 would cost more and overkill for my setup.You must think I'm daft-I didn't realize you were the fellow I suggested this to earlier-I wanted to package it as a box of chocolates...have you considered just putting one together on your own? Buy a kit from Ghent (case and wiring) and a module and viola! It's not terribly daunting and far cheaper than buying one already assembled.
Can't you order modules from Ebay or off AVS Forum? I believe I saw some modules for sale on AVS forum last night.I did consider but I can't get hold of NC252MP or NC122MP. NC400 would cost more and overkill for my setup.
Me too.I could literally ride my bike to Hypex headquarters
AVS Forums? Did you mean used stuff?Can't you order modules from Ebay or off AVS Forum? I believe I saw some modules for sale on AVS forum last night.
