Yamaha HS5 Powered Monitor Review
D
Deleted member 12642
Guest
yeah was curious about the 7's would like to see 8's too.
Is the review of HS7s still coming? :)
Everything is always "coming." The question is when. :)
I was going to measure it tonight but it would require more work since I recalibrated my scanner and don't have an updated profile for active speakers. So I measured a passive speaker. Will get to it very soon now....
F1308
The wait continues :)
I see...
Patience comes after hope.
But look: JBL Stage A130 has just been reviewed... You are next.
Or the next but one...
Just don't spend your patience, keep hoping.
By the way: I saw a comparison between HS8 and a KRK (which I discovered reacently by chance) and they sounded pretty much the same. Hardly to say which was one or the other. I liked both vey much.
BYRTT
Denmark (Jutland)
Ok, OK, I will measure it as the next speaker after the one I am doing now. :)
Thanks and happy new year, sometimes waiting can be better than publish close to crap performance acoustic review so lets hope for HS7 performance is okay or of better ones :)
HerbertWest
Would four HS5 be a good fit to handle auro3D heights duties in a small 3m x 3.5m room? Air distance to the listener would be ~2m. Subs would take care of bass. Still undecided between HS5 and either the larger HS7, or the smaller (more linear) KH80.
Sean Olive
Audio Luminary
I once read someone hypothesising that the NS10 was favoured for monitoring because of its fast response - something to do with the woofer construction being a straight cone with a seam rather than a curved funnel shape, and that this only worked because it was sealed. Don't recall the specifics, and can't remember where I read/heard it, so maybe it's BS. Interesting though.
Fast response = no bass
in my limited experience. But it sounds better in marketing speak :)
Thomas_A
Sweden
If e.g. bass is too fast or too slow, you need to have a word with the bassist.
617
Somerville, MA
Really the most elegant bass management solution possible, and they were doing it back in the 70s.
Mauro
IMO a fast or tight bass is a bump within the 60-100Hz area. That adds a bit of a kick to bass! I don’t know if someone else agrees :)
Nuyes
Reviewer
South Korea
I measured this speaker a few days ago.
So I'm going to release additional data that I can do in this thread.
This is a multitone test.
And relative to Fundamental.
This is the data for each SPL.
The compression test using a multitone.
tifune
If you could, perhaps add your site URL to your public profile or signature? Also, it would be a huge boon to the community if you could submit your data to https://pierreaubert.github.io/spinorama/
