Yamaha Rx-a4a
jayroam2003
Good morning, thinking about getting a (3ch) external amp to go with my Yamaha Rx-A4A that is pushing (3) 4ohm (88.7 db sensitivity L/R & 85db center) speakers. I have 7 speakers total hooked up. So how important is it to get to reference levels or is any power improvement better than what I’m experiencing now. 50-65 watts vs 250 watts.
antcollinet
UK/Cheshire
And what do you mean by 50-65 vs 250? Where are those powers?
Theriverlethe
On the other hand, Monoprice is running a sale on these great amps:
The power rating is conservative. They offer 90 watts at the "knee" before distortion shoots up, but they're capable of 250 watts burst power. I'm able to run my M5100X at "dangerous" volume levels with no strain, unlike the Yamaha A880 I have plugged into it.
J
jayroam2003
Thanks that’s exactly what I just grabbed. The 5100x. Very happy
antcollinet
UK/Cheshire
Yes power. I put watts after those numbers is it not showing up?
Yes, I know they are powers - where are the numbers from - I assume @Theriverlethe has it correct and you've made an assumption about "all channels driven"
If so, this conition never arises. IMO you can safely assume that real program material will never drive more than the "two channels driven" total rating.
antcollinet
UK/Cheshire
Lack of umpf in the surrounds and center channel.
Unless you are experiencing distortion in those channels then lack of umpf will be a setup issue rather than a power restriction. I doubt your external amp will make a huge improvement - but it is not costing you a fortune either, so a not too expensive learning experiment.
Theriverlethe
It does sometimes make an audible difference in my case, but I can easily drive an A/V receiver into obvious distortion with loud music.
