3e Audio TPA3255 Amplifier Kit 480-1-29A Review
Rate this amplifier (kit):
    Votes: 3 1.3%
    Votes: 7 3.1%
    Votes: 42 18.7%
    Votes: 173 76.9%
This is a review and detailed measurements of the 3e Audio 480-1-29A, TPA3255 based class D amplifier module. It was sent to me by the company in a reference design for ease of testing:
The module is the PCB to the right and costs US 89.99 from company Aliexpress store. This is the mono version (I reviewed the stereo version earlier). The differentiation is pulling the required class D filter into the amplifier feedback loop (PFFB) and with it, essentially eliminate the effect of speaker load on frequency response. Low cost implementations lack this which can make the tonality somewhat variable. Other optimizations are done to extract better performance out of the TI TPA3255 class D amplifier module.
When swapping the stereo module for mono above, I was impressed by the hefty machined aluminum heat coupler. It is quite substantial and spreads the heat nicely to large area of the case bottom.
The included power supply in this sample is MORNSUN LOF550-20B48-C. Specification is 48volts at 6.5 amps with air cooling and 11.5 amps with forced air. Latter allows more than 550 watts to be provided to the amplifier.
3e Audio 480-1-29A Amplifier Measurements
The initial set of measurements match the stereo version so I will quickly go over them:
480-3e audio 1-29A Mono class D amplifier Kit TPA3255 Dynamic Range Measurements.png
480-3e audio 1-29A Mono class D amplifier Kit TPA3255 Frequency Response Measurements.png
480-3e audio 1-29A Mono class D amplifier Kit TPA3255 Warm Up Measurements.png
480-3e audio 1-29A Mono class D amplifier Kit TPA3255 Multitone Measurements.png
480-3e audio 1-29A Mono class D amplifier Kit TPA3255 19 20 kHz intermodulation distortion Mea...png
We get more power:
480-3e audio 1-29A Mono class D amplifier Kit TPA3255 Power 4 ohm Measurements.png
480-3e audio 1-29A Mono class D amplifier Kit TPA3255 max and peak Power 4 ohm Measurements.png
We had 206 watts in stereo. Same improvement with 8 ohm load:
480-3e audio 1-29A Mono class D amplifier Kit TPA3255 Power 8 ohm Measurements.png
Stereo version produced 92 watts.
Interesting to see the transfer function change some in this version:
480-3e audio 1-29A Mono class D amplifier Kit TPA3255 Power 4 ohm vs frequency Measurements.png
Cleaner than mono at first but then worse at higher frequencies. Here is the stereo version again:
I captured the switching frequency and was impressed by how low its level was, and how high the frequency was:
Amplifier Reactive Load Test
This is one robust amplifier, essentially not caring about the load down to impressive 2 ohms!
480-3e audio 1-29A Mono class D amplifier Kit TPA3255 Power Inductive Measurements.png
480-3e audio 1-29A Mono class D amplifier Kit TPA3255 Power reactive Measurements.png
You get nearly 600 watts here! :eek: Note that the test only keeps the amp at these power levels for short period of time so this is not "continuous" amount of power in the pure sense of that term.
I don't know what to be more impressed by: the TI TPA3255 or 3e Audio's engineering skills. This is an incredibly well performing at this price level. Of course you have to account for adding a capable power supply and case to get these numbers but still, one can't help but be impressed.
I am happy to recommend the 3e Audio 480-1-29A, class D Amplifier.
Manufacturer Specifications Amp Module:
  • < 85uV Output Noise (AES17,A-weighted)
  • 480W @ 1% THD+N, 1kHz, 2Ω
  • 600W @ 10% THD+N, 1kHz, 2Ω
  • 111dBA dynamic range
  • THD+N < 0.01%, 0.3W – 300W, 3Ω
  • 90% Efficient Class-D Operation (4 Ω)
  • Fully differential layout design for lowest noise and distortion
  • Very Compact size(105mm*90mm*38.5mm – L*W*H)
  • Additional power ON/OFF reset circuit for Pop noise suppression
  • BTL configuration only for best audio performance
  • AUX Power Supply Output(12V/0.2A) for DSP Pre Amplifier
  • Single supply voltage range 24V~51V(UVP:24V)
renaudrenaud
Tianjin
Thanks @amirm.
I bought 2 EVM from Texas Instruments yeeeeaaaars ago, when Ti sold them at 50%, it was 75$ each one by this time. Played a lot with the jumpers, used them in XLR and mono and was never deceived. I spent a lot of time reading the documents from Ti, testing another cards (some from 3eAudio). Sure, this is the DIY way, but a cool way to waste the time with cool projects.
Publishing your measurements is a way to "officially" validate the DIY way with low cost components. Thank you soooooo much.
HarmonicTHD
We get more power:
Question.
Why doesn’t this graph show the 102dB SINAD for 1kHz at 5W which you showed in the scoreboard. Is THDPlusN slightly differently defined?
Thanks.
Edit. Sorry. My bad. Answered below.
sarieri
Question.
Thanks.
Watch out for the bandwidth. This test has to be done at 45khz BW because otherwise 5/10/15khz and its harmonics are almost pointless.
HarmonicTHD
Ah yes. Thanks. I am on an iPhone ATM and missed the small print. ;-)
natna
Wow! Nice performance.
Let's hope these modules find the way to the usual EU vendors in good pricing.
2 x 3E modules + a serious PSU = Dual mono heaven for the years to come!
Thanks Amir!
Koeitje
Not bad for about €200 for a finished product (if you use a very cheap case). But that's still in the range of the cheaper Hypex offerings. So its competitive but not ground breaking.
JeremyFife
Scotland
Decided not to vote in order not to skew results.
It's clearly a very good amp module, but as a DIY proposition I'd never know if I had implemented it correctly.
Impressive and, for me, one to watch out for if suppliers start offering finished units ... although I'd still look for measurements of those implementations.
It does feel that very high quality amplification is getting cheaper. That's fantastic.
Bruce Morgen
That SMPS goes for over $140 USD via Digikey. I wonder if the board's exceptional performance would be impacted if powered by one of the usual sub-$50 USD generic "power bricks" (and industrial PSUs) commonly used with other low-priced TPA3255 implementations.
Bruce Morgen
Ah, I see 3e themselves offer that SMPS for considerably less -- stand down from red alert! :cool:
daniboun
France (Lyon)
Thanks again Amir for this review. I was impatiently waiting for it)
I am currently working on a DIY dual Mono project based on this 3E Audio module. I will soon open a thread for this purpose for those interested.
In all this already confirms what had been demonstrated with the Stereo module, the performance remains excellent with a phenomenal performance/price ratio)
daniboun
France (Lyon)
@99€
You will find some measurements with 34-36V PSU here, as already sais, the TPA3255 chip has a better THD+N figure with lower voltage
Sokel
Problem with these kind of projects are the people lurking the forums trying to make profit under the hood "offering" the assembly as a service but with no official credentials,warranty,etc.
It's an ancient problem but people are hopefully suspicious enough these days.
Other than than,great power (with the proper PSU)
Thanks Amir!
daniboun
France (Lyon)
Thanks Amir!
I am a very good Audiophonics customer, I have shared the ASR reviews with their technical department. They should order Mono modules shortly to have stock in Europe.:)
