Asus Xonar Essence STX vs Fiio K5 Pro ESS
DreaminquE
Hello. I already have the asus xonar essential stx. Would you recommend fiio k5 pro as a desktop dac?
Doodski
It's nice when the person asking the questions posts links so we don't have to search out stuff. Did you get the model name correct or is this some Google screw-up?
DreaminquE
DreaminquE
i have asus xonar essence stx. fiio k5 pro ess looks useful I wonder. I was wondering about your advice.
Doodski
You are running headphones? If so what headphones?
DreaminquE
DreaminquE
I am using a stereo sound system. I think it would suit me better for portable sound level and I am wondering about ess chipset. Is there any difference in sound quality?
Doodski
From the ASUS Xonar Essence STX to the Fiio K5 Pro with speakers you won't hear a difference if you blind test and level match. I doubt you will hear a difference when testing with headphones too. The ASUS is getting old though and drivers are dated and not available for Win11. If me I would run the ASUS for awhile till something more decent for a upgrade path comes along. Are you using PEQ on the desktop for sound improvements?
DreaminquE
DreaminquE
ASUS Xonar Essence STX'ten hoparlörlü Fiio K5 Pro'ya kadar kör test ve seviye eşleştirme yaparsanız hiçbir fark duymazsınız. Kulaklıkla test ederken de bir fark duyacağınızdan şüpheliyim. ASUS eskiyor ve sürücüler tarihli ve Win11 için mevcut değil. Ben olsam, bir yükseltme yolu için daha iyi bir şey gelene kadar ASUS'u bir süre çalıştırırdım. Ses iyileştirmeleri için masaüstünde PEQ kullanıyor musunuz?
I am using windows 11. What kind of adjustment should I make for the sound quality on the computer I do general work on?
Doodski
Have you ever used a EQ? A PEQ is better that's all. For Windows PCs install this and then install this and open the Peace EQ and set auto updates to disabled so it does not forget your settings during a update. Set the bass and treble sliders where you like them for best sound quality. Much bigger changes than any DAC can ever provide. DACs don't generally have a sound.
DreaminquE
DreaminquE
will try. thanks.
