Buckeye NC252MP Stereo Amplifier Review
Rate this amplifier:
    Votes: 11 3.7%
    Votes: 22 7.5%
    Votes: 174 59.0%
    Votes: 88 29.8%
AdamG
Enjoy the Music your way…
Moderator
Reality
I know that feeling, yo!
Post in thread 'Buckeye NC252MP Stereo Amplifier Review'
https://audiosciencereview.com/foru...mp-stereo-amplifier-review.48196/post-1822305
https://audiosciencereview.com/foru...mp-stereo-amplifier-review.48196/post-1822906
You just keep beating this drum…over and over…I’m giving you a break from this Review thread. You ignored my previous attempts to give you subtle advice. :(
Neddy
Wisconsin
Listen Bro, like I’m digging what you’re laying down Dude. But, like, this is a tripping Review Thread and if we don’t tighten up the slack around here dude. That Moderator Cats is going to come in here and ruin our buzz. So like, we don’t want that Bro. We had better take this side convo to the down lo (Any of Buckeye’s Build Threads listed in his signature) before the fuzz gets back. See ya there bro.
Smoking Lamp is Lit.
Good 'pointed' response, and gave me a huge laugh.:D
I worked with an engineer who wrote a 'jive' version of the equipment help/prompt files (IRCC, the 'Format Disk?" prompt was hilarious?).
It absolutely cracked us up - until somehow a customer ended up with a version of it, and that joy ride came to a crashing end.
Merry Happy Xmas!!
Descartes
Who else offers this kind of value?
Monolith by Monoprice M8125x 8x100 Watts Per Channel Class-D Multi-Channel
Home Theater Power Amplifier with XLR Inputs
NC252MP for $1,999.99
Rick Sykora
Stow, Ohio USA
Lol, when you can find it in stock!
Should be a better deal when you buy more channels anyway. Not sure why anyone would be willing to spend 4 times more for a multichannel amp if they only need a stereo one. :confused:
Julf
Amsterdam, The Netherlands
Maybe someone like me with 4-way active speakers? :)
Rick Sykora
Stow, Ohio USA
Ok, but in your case, a single Buckeye amp (as reviewed here) may be a good value but leaves you quite a bit shy of a full range listening experience! :D
Descartes
I need multichannel amplifiers
mdsimon2
Detroit, MI
Still, the Monoprice is not that good of deal. You can get 4 audiophonics stereo NC252MPs for less than $1900 shipped to the US. And although you have more boxes / power cords, stereo amplifiers are easier to resell and you can easily add / remove / move channels around.
Michael
Rick Sykora
Stow, Ohio USA
Thanks for clarifying but hopefully you now see why this post is problematic in a review thread. Suggest you try another thread like the following or start your own.
rdenney
Given the bland look the amp is critisized for by some, he comments that it doesn't matter as his sales has gone up.
I comment that he couldn't possibly know how it would've been, had it had a different design.
Had the price been higher to accommodate a showier case, I wouldn’t have bought my Buckeye amp.
Rick “one data point for you” Denney
Repdetect
Thanks. It's a shame it's not closer to home, but hard to avoid these days.
Yes virtually impossible to avoid, but China most always means lower cost than US buying from EU or vice-versa, no?
Five24287
I have noticed that my buckeye amp clips(the orange led comes on) while driving elac db6.2 . My impression was that they being 6ohms speakers, the amp won't clip. Do I have something wrong in the setup or is that expected? I am using them elacs as rear surround.
Buckeye Amps
Definitely not expected, feel free to message me to troubleshoot.
antcollinet
UK/Cheshire
Does the clip indicator come on only for voltage limit? Or is it triggered also for overcurrent?
But why would it be restricted with 6ohm? Regardless of average impedance, the impedance characteristic will be significantly higher than that for a large proportion of the response.
EDIT : It is 8ohm or more for a large part of the 20 to 100Hz range, and for everything above about 800Hz.
Rick Sykora
Stow, Ohio USA
The intrinsic Hypex response for their MP series is here.
In this case, it is more of a general error indicator. Newer Buckeye amps have a processor that monitors the signal line and may also add some different behavior(s), but the basic behavior is as described in the above post.
rdenney
That’s what Hypex told me, too: Output does not equal input. What I didn’t get from them was what quantity of difference would it take. It is definitely below the threshold of audibility, and I’m guessing no more than 1% difference. That may vary depending on the shape of the error.
I am able to see flashing indicators with my NC502MP Buckeye amp playing uncompressed drums very loudly into Revel F12 towers. Those are nominally 6 ohms, but I doubt that’s important. Did I say it was very loud? Few commercial recordings are as dynamically recorded and mixed as the one I was using.
Rick “wife not home and cat hiding under the bed” Denney
