Fosi Audio V3 Mono Amplifier Review
Rate this amplifier:
    Votes: 7 1.5%
    Votes: 11 2.4%
    Votes: 95 20.3%
    Votes: 355 75.9%
yuki
It would be great if you could put two of these amps inside the LC30 case!
My ramblings aside, thanks for the great amp!
staticV3
I am wanting to hook a pair of these up to my AVR. Its a yamaha RX A770. It doesnt have any preouts for the mains. Only for zone 2. Would something like this work acceptably to convert the speaker level output to a preamp level? https://www.audiocontrol.com/car-audio/factory-system-upgrade/lc1i/
Having the Yamaha's Line level signal be amplified by the built-in Amp, then brought back down to Line level via the adapter, then once again amplified to Speaker level by the Fosi, sounds extremely inefficient.
Instead, I'd try to modify the Yamaha by adding RCA Line outputs myself.
There's a service manual available online which guides you through the disassembly process and contains detailed block diagrams and PCB schematics.
sl1982
Why not use zone 2 line out?
The idea was to have multichannel audio still functional. I am not sure if you could have left and right on zone 2 preouts while utilizing all the other surround speakers. Granted i have never attempted it yet.
sl1982
After looking at the service manual i dont think this is in my skillset. While i do know how yo solder i have no clue where i would need to tap into.
Rafaille
According to the manual you can activate Zone 2 with a button. I would be surprised if it deactivated the main zone, only one way to find out though....
If it works, you will probably have to consider the delay between the different channels, that could be trickier.
EddNog
What is the difference between separate 5A power supplies and on 10A supply? What is the design benefit you mentioned? Thanks
There is actually a pretty decent answer to this in their newly posted FAQ:
-Ed
EddNog
@Fosi Audio congratulations on landing APOS distribution!
SMen
Actually this is also answered differently. @great04
The "design benefit" is in bold from the FAQ
When powering a V3 Mono device, would using a 48V/10A power supply provide a higher power output than a 48V/5A power supply?
Based on our measurements, when powered by a 48V/10A power supply, there is no significant increase in power compared to using a 48V/5A power supply. This is because the power has essentially reached the maximum supported by the TI TPA3255 amplifier chip with a 48V voltage input. Increasing the current further does not directly enhance the power output. However, using a 48V/10A power supply compared to a 48V/5A power supply can provide a higher current capacity and greater safety margin for the amplifier. This increased current capacity effectively reduces voltage drops in power lines and internal circuits under high loads, improving the response of the amplifier when handling dynamically complex audio signals. Moreover, the higher current output means that the system is less likely to overheat or shut down due to current overload when facing peak loads, thereby enhancing the overall reliability and stability of the system. Additionally, opting for a more robust power supply can alleviate the operational stress on various components of the amplifier, prolong the lifespan of the equipment, and offer more flexibility for potential system upgrades in the future.
My small issue with this is that Aiyima have a 48V/10A GaN supply that is much less expensive than the Fosi 48V/10A.
So there is a design benefit, and a profit benefit, which is fine ... but in a marketplace ASR could assist in comparing the impact of these power supplies with regard to measurements of the complete amplifier units.
We could power two v3 Monos with two 48V/10A supplies from Aiyima for the reasons/benefits in bold from Fosi, but for much lower cost - if we had the measured performance information relating to the power supplies!
The power supplies cost as much as the amplifiers or more.
For good reason perhaps or not, I'm a 'believer' in the importance of power supplies.
wyup
Bilbao, Spain
Why not use RCA to XLR adaptors instead of RCA input for better performance?
RCA inputs have additional and innecessary gain as well as op-amp 'converter'.
XLR has enough input impedance to drive single-ended voltage.
drmevo
I was wondering this too but it seemed so obvious I figured I was missing something.
Abstracted
Anyone willing to bet we're NOT going to hit the $300K mark by the deadline?
hello_again
Likely won't hit the $300k mark, but if they can pull another $25k in organic sales, the you just need to convince about 900 backers to add (1) Muse02 add on and your right at the $300k threshold... so I'm saying there's a chance. What's strange to me is there seems to be little participation from Japan or Korea. Would have figured there would be more interest, maybe Fosi needs to send some Asian influencers demo units.
Negatywny
warsaw
what? We're at almost 85% to final goal of the campaign, and there's still 90% of the time left. So i'd say it shouldn't be a problem? I assume that there is more press/media coverage/attention coming in whole next month, and news in style of "spectacular success of kickstarter audio campaign, audiofile holy grail for normies, check it out, thers still time for you to pledge and be a part of history" ;).
