John
John but you are a DAC 'designer ' you must have measured the output of the dacs you 'design' thousands of times, show Amir where he is going wrong.What a ridiculous reply.
Does peer reviewing require someone submitting alternative measurements?
Did pointing out Amir's original flawed 8dB difference in his measurements require that alternative measurements be done?
If you can't understand the logic and/or the technical points being made then you really can't add anything to the discussion.
