Thanks Michael. I am pleased to see the industry try to address this topic. But I am at a loss as to where they are going there. Seems like they are confused about what I have tested. Wish they had contact me prior to writing their multi-part response.
So to bring clarity, here are the two configurations I have tested. Case 1, is their iFi DAC directly connected to my laptop with USB to feed it digital audio, and its only analog output which is unbalanced, to the Audio Precision's unbalanced inputs for measurement:
This configuration performs great. As noted, the Audio Precision analyzer is replacing your pre-amp with unbalanced inputs. It would be how I use the iFi iDAC2 in my music system when it is not being put to use here.
Here is the Audio Precision analysis of what was fed to it over those RCA jacks from ifi DAC2:
This was our reference and "control" if you want to be "scientific."
The next configuration was to insert microRendu in the chain. Since it is a networked device, the picture looks busier:
The
right hand stayed the same: Audio Precision acting as the pre-amp receiving what iDAC2 give it as before. The connection from my laptop to microRendu was over wireless to my home gigabit Ethernet switch. micoRendu was powered with the iFi iPower power supply that I purchases as a package. It was one system or a "black box" in engineering terms. It is exactly what someone in my position would do in their system.
As before, the Audio Precision is standing in for your pre-amp. It is not some special connection or configuration. RCA audio out comes from iFi iDAC2 as before and feeds analog audio to Audio Precision. Audio Precision digitizes that signal and performs a fourier transforms on it which shows its frequency components as reported before:
It is clear that making this configuration change in the chain of audio (and NOT the Audio Precision) has caused these new, correlated, mains related distortion/noise products to appear.
iFi and prior to them, Alex/John seem to be saying I created a ground loop and that is my problem. Their argument holds no water unfortunately. I have done nothing that a customer would not do. My ifi DAC2 only has unbalanced connection. It does not have balanced output for me to have used.
iFi talks about lack of galvanic isolation in Audio Precision. I am sorry but I have not heard of amplifiers with unbalanced analog audio inputs having galvanic isolation. If the combination of iFi Power and microRendu create a ground loop between them (which they may very well do), and that in turn gets through iFi's own iDAC2, then between them they have created a non-performant system. It is indeed one of the perils of adding this class of device which is created by needing yet another power supply.
Regardless, I can't emphasize enough that what I am measuring is what is seen by any pre-amp. Arguments of ground loop being specific to my setup doesn't hold water. If a $600 audio-optimized network streamer can create ground loops when paired with iFi's DAC, they need to fix this. For $600, they could have galvanically isolated the USB output if they wanted. If they have not, and noise is travelling all the way from a power supply, through microRendu, then iFi iDAC2 to my analyzer, then I am not happy about this situation. They need to build a more optimized solution that doesn't create problems that vast majority of customers without instrumentation would be blind to.
Finally, I want to make sure they are absolutely clear that I am NOT, let me repeat, NOT measuring their power supply. I am measuring the output of their DAC. Per above, I am measuring a system, not a component. My read of a lot of their comments about how they use the Audio Precision is that they think I am measuring the power supply. They say things like using transformers in front of the Audio Precision analyzer. I can't imagine them only testing their DACs through transformers. Power supply noise measurements, yes. But not DAC output.
Anyway, I look forward to the rest of their response. Hopefully it has a measurement of the system as I have pictured above. And as always, I welcome all new data, challenges, corrections, etc.
