OK, some more data
For the avid readers of this thread, you know that I have shown the fault where new distortions are created to the the combination of microRendu and iFi iPower power supply. I attempted to isolate the issue by using a linear power supply and the problem went away. I thought I do the reverse test which is to keep iFi iPower but do away with the microRendu and see if the performance of iFi iDAC2 is impacted still. This has become important as iFi is pointing the finger at the measurement system being the problem and not a system issue.
So here is the new test setup. The first test was my "control" as before, using the iFi iDAC:
For the second test, I inserted the Uptone Regen into the picture. This allowed me to use the iFi iPower as the power supply for Regen and hence the DAC:
This is the outcome:
We see that the two measurements almost perfectly land on top of each other. The only difference is that we now have addition of a couple of spikes at 8 and 16 Khz. We know from testing of Regen last year that it is at fault (again with combination of external power supply) for inserting these USB related distortion products. So we can ignore that for this situation. After doing so, we see that iFi iPower has NOT contributed to degradation of the iDAC2 as it did when it was paired with microRendu!
Putting two and two together, the only time we seem to have this kind of problem:
is when we pair microRendu and iPower power supply together. With other combinations this problem does not exist in my testing.
Importantly this busts the latests theory that the above observed problem is due to ground loop errors.
In these latest tests we have the same identical measurement system of my laptop and Audio Precision analyzer, and iPower power supply and the DAC, yet no mains related distortion problems.
In summary, as I have been saying,
iFi and Sonore need to get together and resolve whatever problem the pairing of their two products, the iPower and microRendu, are having. It is not a phantom problem. It gets created only when these two products are put together. Independent testing of iFi iPower as iFi has been doing is useless in figuring this out.
As always, I am open to feedback, corrections, new data, etc. from manufacturers. I hope they use this opportunity to improve their products for their customers. The opportunity is in front of them.
