Room Measurement Tutorial for Dummies Part 1
DonH56
Monument, CO
That will not necessarily get you absolute SPL accuracy; not all cal files include the sensitivity parameter (mine did not). But maybe they do now? I have not used it for a while.
Sal1950
The Chicago Crusher
Central Fl
Here's the two I got with mine?
Also I tried pushing the Calibrate button in the SPL app and it puts up a dialog box the says the umik doesn't require calibration, it was already included in the file.
  • 7018710.txt
  • 7018710_90deg.txt
DonH56
Monument, CO
Thanks guys. I checked my notebook and sure enough I have a cal file from miniDSP with the sensitivity parameter set. Oddly, the cal file from CSL (where I bought the mic) does not.
FWIW I checked the UMIK-1 using the CSL cal file to my Earthworks and they were almost identical in frequency response. There was a little deviation using the miniDSP file, mainly at LF and very HF. Not enough I would worry about it, but being one of those anal engineer types am glad I bought the CSL version. At the time of purchase, miniDSP did not have 90-degree files, which would have led to a much larger error.
JohnPM
Herb didn't include the sensitivity figure in his cal files as he didn't have a way to verify it, but these days he includes a version with the miniDSP sensitivity figure in an REW folder on the USB stick containing the cal data.
Side question: you are not by chance the JohnPM who is the author of REW, are you?
Oh, wow. You should have told me. You are a heck of a lot more modest than I would be. :D I gave you an appropriate title.
I would love to learn more about the history of REW and motivation for creating it. Do you mind sharing that in a new thread?
Sal1950
The Chicago Crusher
Central Fl
Donald
Amir:
Despite years of DIY speaker and PC building and somewhat related formal education (PhD in Physiological Acoustics) I've encountered numerous obstacles in my efforts to understand REW. I had just about about given up on the application when I came across your tutorial. Your detailed descriptions, together with helpful information from contributors to this forum, have enabled me to at least begin to make use of this remarkable free software.
Thank you!
Donald
@Amir,
Are you still working on Part 3, or have you just ditched the idea?
Kind regards,
J-J
No, it is on TODO list. Just when I get to it... is not clear. :)
Wow, it works! :)
Am I correct believing that this device (https://www.minidsp.com/products/minidsp-in-a-box/minidsp-2x4-hd) can load the filters generated by REW and correcting the response of my speakers and room?
Yes, REW can generate the filter settings for a number of boxes. Even when it can't, you can get the list and manually put them in there.
In my experience though, the auto-generated ones don't always sound the best. They attempt to get maximum flatness which may not be what sounds best. Good news is that with these type of DSP filters, you can turn them on and off and hear the difference.
Krunok
Zg, Cro
I see, thank you. What do you think is a better alternative to the auto-generated fitler settings? Adjusting the target curve to something other than the flat line, say increase the bass response in 50-100 region and introduce slight roll-off in highs?
Krunok
Zg, Cro
Btw, do you still plan to do a Dirac Live test with miniDSP SHD? Maybe it can serve as some kind of reference point for REW..
