Model is the "Moab Be", .... Too hot by about 5 dB from 33 to 200 Hz
All Stereophile measurements of the overall frequency response are incorrect below 200-300Hz.
When combining gated and nearfield measurements, the half-space (2pi) to full-space (4pi) transition of the nearfield measurement is not taken into account.
You are probably the thousandth person to misinterpret the faulty measurements
of by Stereophile. It is a complete mystery to me why Stereophile continues to use this incorrect representation of the overall frequency response of a loudspeaker or at least not puts a huge warning on the diagram explaining the incorrect presentation.
Depending on the baffle dimensions, the SPL must be reduced by 6dB below 200-300Hz in the Stereophile diagram.
It is also a pity that Stereophile does not question Tekton's marketing story at all, but reproduces it one-to-one:
Stereophile:
You see, years earlier, one of Alexander's most eye-popping and ear-pleasing ideas had been to cluster seven small high-frequency drivers in a tight circle and set the crossover to feed them midrange and low-treble only (in the case of the Moabs, between 772Hz and 3.41kHz). The cluster acts as a midrange driver with unusually low mass and thus exceptionally quick response. This helps especially with delicate overtones and harmonics, whose formation can be smothered by slower, traditional midrange cones.
As long as the driver used exhibits piston-like behavior, the size of the driver and the mass of the driver doesn't matter - e.g. cone mass can be counteracted with "stronger" driver motor to reach the same SPL.
A very nice real world example of the relationship between dome mass and SPL can be seen in the midrange domes from Bliesma. As long as the driver behaves ideally (piston like behavior) the mass only influences the SPL of the driver (the driver with heavier Al-dome is as "quick" as the lighter Be-dome ):
Source: HifiCompass
The driver with the lowest Mms, Be dome, shows the highest SPL and the heavier Al dome runs perfectly parallel (till about 5kHz) but with lower SPL with identical drive motor.
With a dome mass in between, the silk dome shows as expected a SPL in between, but due to the lower stiffness, it no longer shows ideal behavior much earlier.
But of course, in reality resonances inevitably occur. As the cone or dome area of a driver increases, resonances such as eigenmodes or surround resonances...., are shifted to lower frequencies.
The occurrence of resonances naturally also depends on the dome or cone material and surround material used. A pure paper cone or silk dome shows no more piston-like behavior at lower frequencies than when stiffer materials are used (see Blisma midrange example above).
One could now start a "high-end" argument that every resonance requires a certain settling and decay time and therefore affects the sound. And that out-of-phase resonances cause a wavy frequency response.
This is not wrong in principle and every woofer, for example, shows a more or less pronounced out-of-phase surround resonance.
Here is an example of an 8'' fullrange paper driver with severe out-of-phase surround resonance at 480 Hz:
If one follows this line of reasoning, then one should therefore avoid the resonance frequency of a driver in the used range as well, as the driver usually exhibits particularly pronounced settling and decay behavior there. So at all cost avoid to use a tweeter in the range of its resonance frequency - Tekton does the opposite with the tweeter in the "circular midrange array". So this "high-end" argumentation cannot be applied to Tekton.
Since it's Stereophile we don't have distortion measurements or understanding of what the speaker measures like at high volumes so the question of Sd, Xmax, and dynamic range is unanswered, but from this review it's still not looking good for the tweeter array concept.
Since the usage of the SB Acoustics Satori Berylium tweeters and the 772 Hz crossover point are explicitly mentioned, I would personally rate this design as problematic.
SATORI TW29B / SATORI TW29B-B: fs: 600Hz
SATORI TW29BN / SATORI TW29BN-B: fs: 700Hz
SATORI TW29BN-8 / SATORI TW29BN-B-8: fs: 750 Hz
crossover point is extremely close or even at resonance frequency.
The Moab uses 2x7 tweeters in the midrange array. This means that the excursion hardly plays a role even at the resonance frequency of the driver. Especially as the SPL at the alleged crossover frequency of 770Hz is already -3dB or -6dB, depending on the filter used.
Even without any filter (i.e. only the high pass behavior of the tweeter), 14 tweeters should have no problem with excursion at normal SPL <110dB.
