- Joined
- Feb 5, 2019
- Messages
- 3,688
- Likes
- 4,071
Agreed. Open Pandora's box.Do I have the authorisation to open the box?
Yesterday night, I was so eager to try this amp, so I didn’t open the case before listening it for the first time.
After connecting power, dac and speaker, when I turned on the amp, there is hiss noise coming from speaker, loud enough that I can hear it from 2 meters away. My other amps don’t have this hiss noise, speakers are pretty quiet, I can only hear a small amount of hiss when my ear touches to the speaker. The hiss volume is consistent and doesn’t change with volume knob turn. I bought a pair of opa1612a, hoping to alleviate this hiss problem.
Besides the hissing noise, the amp is quite good, powerful enough to drive my kef ls50. I turned the volume to the max and control the volume through e30. The sound is pretty clean, I particular the low frequency is tight than my Emotiva A300, but the sound is a little flat, a little less dynamics compared A300 and M28.
I listened only for a couple of minutes, this is my initial experience. If opa1612 will solve the hiss problem. I am super happy with this little guy.
Are you sure it's a hiss and not a ground loop?
Is it still there if you disconnect the source? Can you try connecting the amplifier to a separate power socket?
Is your speaker cable connected only to this amplifier?Just tested again as you suggested, I removed rca inputs, the hiss/humming is still there and doesn’t change with the volume up or down. So it’s highly likely a ground loop problem. I tried to use another power socket, no change. How do I solve this?
My speaker(kef ls50) only connects to SY-2002.Is your speaker cable connected only to this amplifier?
Is there any wiring that connects to other amplifiers in the speaker wiring?
Are you connected to a speaker select switch?
Unfortunately, my cause prediction was wrong.My speaker(kef ls50) only connects to SY-2002.
Actually after your tests I'm more oriented to say it's a defect because it's strange that the amplifier isn't properly grounded to the chassis. Can you check with a voltmeter if there is continuity between the rca shields and the chassis? Be sure to check on a point where the chassis painting has been scraped or on a metal screw that goes through the chassis. If there is none, you can try running a wire from one of the rca shields to the chassis and check if the hum disappears.
It seems that there is no problem with the power supply line and speaker wiring from the situation, so a possible confirmation check is to check if the noise disappears when the power is turned on with the OP amplifier removed from the socket by opening the case cover.
@molexey
very sorry about this there is an quality issue on these 2 small capacitor. we will ask SMT supplier improve this in further build.
regarding the BIG SMT cap is not impact function as there are 3pcs 2200uF, and in Rev1.1 design we already remove it and just keep 3x2200uF.
i suggest if you are able please swap the position of these 2 small one capacitor either remove them(cut it form the board).
or you can contact us for another replacement.
The voltage of 48V is not a problem electrically.hi @3eaudio I'm tempted to buy one of your TPA3255 integrated Amplifiers but I realized reading specs you suggest it is for 8ohm speakers while the 3151 is for 4ohm. can you pls clarify? now I'm successfully using your TPA3255 stereo version in a DIY final Amp with 48V 17 Ampere peak with 4ohm speakers. it's very good, coils become pretty hot. ok to drive it at 48V?
thanks
L.
However, forced air cooling by a fan is required depending on the usage environment.
I used to use it at 48V at first, but in the summer it got so hot that the heatsink didn't touch it, and now it's down to 43V or less.
