ABX complex non-linear distortion test, about 5% on a music sample
pma
Prague
This is the test on audibility of complex non-linear distortion. There are two test files, Quintet1 and Quintet2, one of them is the original and the other one is distorted. The link to the zipped test file is:
https://www.dropbox.com/s/kg8abarbdivr9na/quintet_test.zip?dl=0
If you would like to participate in the test, please download the test file (you do not need to have a dropbox account. Click somewhere outside log-in window and then click to download the quintet_test.zip file. Do no try to play the files directly from dropbox, it is impossible.)
There are 3 files in the zip, the 2 test files and a difference file, that demonstrates, by listening, how big (or small) was the distortion used. As a plot, please see the distortion profile below.
In case you want to participate, I would ask you to make an ABX test in Foobar 2000
http://www.foobar2000.org/components/view/foo_abx
and then to post the full protocol of the test, which we are able to verify at
https://www.foobar2000.org/abx/signaturecheck
I have borrowed the music sample from @Mario Martinez and I hope he would not mind.
Have fun listening the samples!
pma
pma
Prague
OK I will start. This is my result
Code:
foo_abx 2.0.2 report
foobar2000 v1.4.8
2020-12-08 16:42:36
File A: Quintet1.flac
SHA1: 78941da5875a6dc51169e29bbbb909399b75c377
File B: Quintet2.flac
SHA1: 2cea48c9ec2b493807e65e1d2b49deb19b543939
Output:
ASIO : Creative Sound Blaster ASIO
Crossfading: NO
16:42:36 : Test started.
16:43:32 : 01/01
16:43:50 : 01/02
16:43:59 : 02/03
16:44:08 : 03/04
16:44:33 : 03/05
16:45:13 : 04/06
16:45:37 : 05/07
16:45:47 : 06/08
16:45:56 : 07/09
16:46:06 : 08/10
16:46:06 : Test finished.
Total: 8/10
Probability that you were guessing: 5.5%
 -- signature --
0b4deacf8293b861f769b4e98db66bc60a645bf6
pma
pma
Prague
So nobody yet, quite as expected. If there is hardly anybody who can hear such high distortion on music, so why there is a challenge of the -120dB THD??
I am posting distortion plots at lower level, still very very high.
The difference file in the zip is included for the reason to be able to find the loudest and most distorted parts of the music sample and to use these time interval in the ABX test. The distortion is even harmonics only and similar to SE tubes. There is a wrong belief that even harmonics make the sound more "pleasant". This is a nonsense, because the even harmonic also create difference IMD tones and these are the most audible distortion components.
Blumlein 88
The usual excuses. I used my Lenovo Ideapad on board sound to drive Sony headphones. It was late. I've had two glasses of wine. Now other than the wine, I don't think anything was an impediment. Certainly the gear is well below 5% thd.
EDIT:eek:ops I just noticed upon reading the original post you wanted me to post this at the signature check. Sorry. If I try again later, I will.
foo_abx 2.0.6d report
foobar2000 v1.5.3
2020-12-09 02:30:32
Output:
DS : Primary Sound Driver
Crossfading: NO
02:30:32 : Test started.
02:35:17 : 01/01
02:35:29 : 02/02
02:35:39 : 03/03
02:36:02 : 04/04
02:36:15 : 05/05
02:36:23 : 05/06
02:36:40 : 06/07
02:36:49 : 07/08
02:36:59 : 08/09
02:37:09 : 08/10
02:37:09 : Test finished.
Total: 8/10
p-value: 0.0547 (5.47%)
-- signature --
6f340f1633e5b00c14542ba09a3ef2f16a40fb2f
pma
pma
Prague
Thank you! Great result! I think that the wine makes the mind open ;). Your signature check is valid, no need to attach more.
I would like to show how the even harmonics create the IMD components
Original sample
Distorted sample. See the interleaved lines at 100-600Hz and 1kHz-5kHz
Blumlein 88
Yeah, with high even harmonics you get a kind of a calliope effect. Like a weird instrument is playing along you just barely hear and it doesn't fit. I've listened to a few S.E.T. amps which had too hefty a speaker attached which sounded that way.
I'm not surprised by the low participation. Whenever I've attached files and asked people to choose everyone is afraid.
MarsianC#
Austria
I'm super uncomfortable with this music. However, first try, Aurora DSP/Atom with 990 Pro, no EQ:
foobar2000 v1.6.2
2020-12-09 10:55:38
Output:
Default : Primary Sound Driver
Crossfading: NO
10:55:38 : Test started.
10:56:01 : 00/01
10:56:22 : 00/02
10:56:40 : 01/03
10:56:56 : 01/04
10:57:13 : 01/05
10:57:52 : 02/06
10:58:20 : 03/07
10:58:34 : 04/08
10:59:02 : 04/09
10:59:18 : 04/10
10:59:18 : Test finished.
Total: 4/10
p-value: 0.8281 (82.81%)
-- signature --
428be834cd9d13c9a87a4aaa74d62c84630e7289
4/10. Really, I am guessing. Switching tracks is NOT gapless, is it for you?
pma
pma
Prague
foobar2000 v1.6.2
2020-12-09 10:55:38
Output:
Crossfading: NO
10:56:01 : 00/01
10:56:22 : 00/02
10:56:40 : 01/03
10:56:56 : 01/04
10:57:13 : 01/05
10:57:52 : 02/06
10:58:20 : 03/07
10:58:34 : 04/08
10:59:02 : 04/09
10:59:18 : 04/10
Total: 4/10
-- signature --
Thank you for participating! To me, switching between tracks is quite smooth, it may be a case of system setting.
MarsianC#
Austria
I'll check that, Asio is not very stable. I tried cheating with mono and listing to a short piece only. My ears fatigue immediately! Same with Stax Lambda Nova Basic.
Btw I'm 25. Perfect hearing capability to 20 kHz. It must be the gear! :p:p:p
bobbooo
The threshold for decent statistical significance should be at least 13/16 correct trials for an ABX.
hyperplanar
Los Angeles
Code:
foobar2000 v1.6.2
2020-12-09 02:21:35
Output:
Crossfading: NO
02:21:35 : Test started.
02:25:16 : 01/01
02:25:39 : 02/02
02:25:47 : 03/03
02:25:54 : 04/04
02:26:07 : 05/05
02:26:16 : 06/06
02:26:30 : 07/07
02:26:44 : 08/08
02:26:57 : 09/09
02:27:04 : 10/10
02:27:10 : 11/11
02:27:14 : 12/12
02:27:20 : 13/13
02:27:28 : 14/14
02:27:36 : 14/15
02:27:41 : 15/16
02:27:48 : 16/17
02:27:53 : 17/18
02:27:57 : 18/19
02:28:07 : 19/20
02:28:07 : Test finished.
Total: 19/20
p-value: 0 (0%)
 -- signature --
6439baea505b793ddd252eca948135f6c8e0db1b
Do I win something? :p
bigjacko
Can someone explain the math behind p value? I am curious what p value would be if we get 0 out of 10.....breaking math?:eek:
MarsianC#
Austria
pma
pma
Prague
foobar2000 v1.6.2
2020-12-09 02:21:35
Total: 19/20
p-value: 0 (0%)
-- signature --
[/QUOTE]
Great!!!
pma
pma
Prague
It may be googled from probability theory. Below is the chart for X successful trials from 10 trials.
restorer-john
Can I do it in the morning Pavel? It's been a hell of a day and it 10:41pm right now and I too, have had a wine or two... ;)
Reactions: pma
SoundAndMotion
Germany
The third column is not labeled correctly. It is the cumulative probability of guessing X or better.
The probability of guessing and getting 1 or more correct is indeed nearly 1. For 0 or better it is 1.
But if I get 5 profoundly deaf subjects and each answers 0 or 1 correct out of 10, I'm extremely confident, it was not due to guessing. It indicates a systematic error (several possibilities), not guessing. Which systematic error? ...I'd be guessing :D
Reactions: pma
pma
pma
Prague
Yes I know that I am not strong in proper math terms, I took the one from older ABX plug-in description, which was later corrected to "p-value". However, the method of calculation is valid for our purposes and remained the same in both plug-in versions.
Note: we should not make cherry-picking. I, myself, made one test run. It is possible to make some training to be familiar with the files but then please confess if there were more test runs. Personally, I would need at least 15 minute pause before repeating the test. On the other hand, 7/10 and 8/10, even with pause, may be summed to 15/20.
I just passed a 2nd test run, again 8/10
Code:
foobar2000 v1.4.8
2020-12-09 14:37:55
Output:
Crossfading: NO
14:37:55 : Test started.
14:39:04 : 01/01
14:39:17 : 01/02
14:39:28 : 02/03
14:39:46 : 03/04
14:40:08 : 04/05
14:40:21 : 05/06
14:40:34 : 05/07
14:40:47 : 06/08
14:40:59 : 07/09
14:41:16 : 08/10
14:41:16 : Test finished.
Total: 8/10
 -- signature --
562bcd39d8a48f15c5b057b7c46f4cf9918e15e1
pfzar
SF
If you would like to take the test below. It's available until 12-31-20, It's completely anonymous. I will post the data after the test is concluded.
updated LINK
