ABX complex non-linear distortion test, about 5% on a music sample
March Audio
Albany Western Australia
My result 9/10
foo_abx 2.0.6d report
foobar2000 v1.6.2
2020-12-14 08:07:41
File A: Quintet1.flac
SHA1: 78941da5875a6dc51169e29bbbb909399b75c377
File B: Quintet2.flac
SHA1: 2cea48c9ec2b493807e65e1d2b49deb19b543939
Output:
ASIO : MOTU Pro Audio
Crossfading: NO
08:07:41 : Test started.
08:09:10 : 01/01
08:09:25 : 02/02
08:09:40 : 03/03
08:10:03 : 04/04
08:10:42 : 05/05
08:10:58 : 06/06
08:11:34 : 06/07
08:12:26 : 07/08
08:14:47 : 08/09
08:15:05 : 09/10
08:15:05 : Test finished.
Total: 9/10
p-value: 0.0107 (1.07%)
-- signature --
7fec2ca562c35ed808875f085546c109154b2e65
Reactions: pma
March Audio
Reactions: pma
playmusic
First attempt below.
Thank you for setting up this test!
foobar2000 v1.4.8
2020-12-14 18:36:03
Output:
DS : Primärer Soundtreiber
Crossfading: NO
18:36:03 : Test started.
18:36:57 : 01/01
18:37:24 : 02/02
18:37:47 : 03/03
18:38:10 : 04/04
18:38:37 : 05/05
18:38:54 : 06/06
18:39:16 : 07/07
18:39:35 : 08/08
18:40:31 : 09/09
18:40:56 : 10/10
18:41:15 : 11/11
18:41:39 : 12/12
18:43:17 : 13/13
18:43:35 : 14/14
18:44:16 : 15/15
18:44:42 : 16/16
18:44:42 : Test finished.
Total: 16/16
p-value: 0 (0%)
-- signature --
a34ad58cb8b4f55f1bc673b9a44e6bdb544782da
preload
California
I couldn't tell the two FLAC's apart, let alone make an AB selection, so you can count me in as a "fail."
I also don't think THD is as audible as some people think it is.
Thomas_A
Sweden
Just realized it's only doing 2 trials. Editing a new test that will have more,updated link
I've tried a couple of times. Headphone directly into my Mac but are unable to find any differences. Anyone succeeded with your link yet? :)
pfzar
SF
Res-Head
I am 20 years old and cannot hear any difference between the 2 files through my JDS Element, except the difference file which sounds noticeably worse. Which one is the original?
MarsianC#
Austria
I guess we young people are not suited for critical listening. Lmao
I'll try a lowpass filter at 15 kHz (6dB/oct? more?) to simulate my ears in 20-30 years. Lmao²
Propheticus
Vleuten, Netherlands
Well, that was very hard. Half of the time I felt like I was taking the best guess. Had some background noise so had to turn up the volume on my open headphones. Didn't hear any artefact stand out or tell-tale distortion, it was more of a 'feeling' of fullness or pressure being there compared to the other file that did not have this filler.
foobar2000 v1.6.4
2021-02-10 17:00:24
Output:
ASIO : USB DAC ASIO
Crossfading: NO
17:00:24 : Test started.
17:03:49 : 00/01
17:04:22 : 01/02
17:05:49 : 02/03
17:06:21 : 03/04
17:08:25 : 04/05
17:09:20 : 05/06
17:10:31 : 05/07
17:11:00 : 06/08
17:11:32 : 07/09
17:12:25 : 08/10
17:12:25 : Test finished.
Total: 8/10
p-value: 0.0547 (5.47%)
-- signature --
c1eaeffc3a19c6ead3a5d06ddbd5238ce65e4d05
preload
California
It just dawned on me - what volume are y'all listening at? If the volume is normal, the 5% THD products might actually be below the threshold of audibility at their respective frequencies. In other words, the 5% THD might only be audible when the test track is turned up. That might account for some of the differences in performance with this test.
Propheticus
Normally I'm on: 13, to pass this test: 20.
But the samples sounded soft. Possibly due to being classical music and no replaygain. For normal listening I would've upped to 15 or 16.
Not sure this tells you much without reference/scale. Max is 60, but volume control is perhaps not linear.
preload
California
Audibility would be based on dB at a given freq at your ears. Hard to know what your digital volume settings correspond to.
Blumlein 88
The idea would be to set to a normal or slightly louder than normal level you'd normally listen to this. For most people you likely have a sound level of 70-80 db with some peaks higher.
pma
pma
Prague
Thanks for participating! Your guess on an original file was correct. I think we may disclose it, regarding the long time this test has been available.
Not very low and not very high, you need to prevent your ear self-distortion.
preload
California
Sure and it would be nice to control for that by establishing the listening level as part of the protocol. Otherwise you will get a lot of false null hypothesis (no diff) test results if people listen at a level where humans are known not to be able to hear anything at that frequency, whether it's a distortion product or not.
jensgk
Denmark
foobar2000 v1.6.3
2021-04-02 01:14:13
Gain adjustment: +5.14 dB
Gain adjustment: +4.25 dB
Used DSPs:
Skip Track, Resampler (dBpoweramp/SSRC)
Output:
WASAPI (shared) : Hovedtelefoner (USB-C to 3.5mm Headphone Jack Adapter)
Crossfading: NO
01:14:13 : Test started.
01:16:35 : 01/01
01:18:02 : 01/02
01:18:19 : 01/03
01:20:19 : 01/04
01:20:36 : 02/05
01:21:04 : 02/06
01:21:43 : 02/07
01:22:14 : 03/08
01:22:33 : 04/09
01:22:51 : 05/10
01:23:22 : 05/11
01:23:36 : 05/12
01:23:47 : 06/13
01:24:00 : 07/14
01:24:10 : 07/15
01:24:23 : 08/16
01:24:23 : Test finished.
Total: 8/16
p-value: 0.5982 (59.82%)
-- signature --
9e475d8baa5dee06e8bd4fbaaaa4d4aeccfc71fb
Reactions: pma
rkbates
Down Under
Too lazy to attach the pc to the sound system so I just listened to the files. Thought I could tell them apart, then changed my mind on which was which. Clearly guessing. Should be able to save some money on my next purchase. Thanks for posting the files.
2M2B
So nobody yet, quite as expected. If there is hardly anybody who can hear such high distortion on music, so why there is a challenge of the -120dB THD??
Because a Etymotic engineer on Head fi said the upper limit on when THD was a issue was around 2% with music. So that could be why many still find the ER4XR with 1.65% still clean but might sound wrong on pure sines waves?.
