AES3 input, balanced analogue out DAC?
sarumbear
sarumbear
MCH
Member @Semla made a chart of topping DACs features, that seems not updated since long. But it shows two other models that fit your spec for less money than the d90:
Rednaxela
NL
Read further down on that page, please, until you reach the connector standard.
This part? There I’d say they went for the second one. No?
Edit: gotcha. I bet they did so to save space.
MaxwellsEq
JustJones
Could always go all out and get a Weiss 502. It should lift all sorts of subwoofery veils for $10K
sarumbear
sarumbear
sarumbear
sarumbear
Consequently, you can just use a XLR to RCA cable and connect any SPDIF DAC you want. Gives you a lot more options.
Can work but so can a Bluetooth speaker as a Hi-Fi system.
sarumbear
sarumbear
sarumbear
sarumbear
sarumbear
sarumbear
D70s is an option as well.
sarumbear
sarumbear
sarumbear
sarumbear
sarumbear
sarumbear
MiniDSP 4x10HD meets your criteria if you can find one on the used market (I bought at ~$400 USD). Built in equalization.
Thank you but it is an overkill to what I need, besides it doesn't have an integral PSU.
Puddingbuks
@sarumbear what did you end up with?
Looking for the same thing. Want a schiit modius but nowhere to be found.
sarumbear
sarumbear
