@Feesh : I have a WIIM Pro connected to a SMSL D-6s meanwhile. Connection is Toslink.Tried both XLR and RCA - both pop.
Just got the 2nd unit, also has the exact same pop. The pop can occur anytime the display switches to (---), which happens mostly during bitrate switching - it happens 80% of the time. Locking bitrate to 44khz the pop obviously vanishes.
Using Tidal via my PC over USB eliminates the pop completely on the 2nd unit.
Will test using a new optical cable and WiiM Pro... hopefully that combination works better.
Have already tried using the delay while doing all of my testing (up to and even more than 1000ms) and it did not fix the pop.@Feesh : I have a WIIM Pro connected to a SMSL D-6s meanwhile. Connection is Toslink.
Since I mainly use Spotify (my wife's preference - I might actually opt for Tidal) I cannot comment on sample-rate changes.
BUT: I came across a menu item in the WIIM home app (see screenshot). It seems, the WIIM firmware allows to set a latency when switching the sample-rate. The default was 0ms as far as I remember. I have set it to 1000ms (maybe 100ms would be ok. as well - I've not played with this setting), just because I thought 0ms might cause an issue.
-> You may want to try to configure a latency and see if this eventually solves your pop noise issue
Switching from XLR to RCA did not have any positive effect, both connections exhibited the pop.Feesh, am I reading your test write-up of February 15 correctly, and all cases of D6-s pop are via the XLR outputs? No cases of a pop when using the RCA outputs? Thanks.
The RCA output indeed just sums up (precisely speaking subtracts) the XLR output. If the XLR 'pops' the RCA will 'pop' too.Switching from XLR to RCA did not have any positive effect
The DO300 has an option to output XLR or RCA seperately, or both at the same time.The RCA output indeed just sums up (precisely speaking subtracts) the XLR output. If the XLR 'pops' the RCA will 'pop' too.
The RCA outputs do have their own muting switch, but I suspect all of the outputs get muted with the same signal.
I'm actually wondering, why SMSL missed the opportunity to mute XLR and RCA separately. The Topping E50 e.g. does allow to activate RCA or XLR or both, which is a nice feature if you have the speakers connected to XLR and the headphone amp to RCA.
DSD Direct ≠ Native DSD.Hi PhnomPenhPaul,
Get informed first, what you say isn't true.
I have a Topping E70 and this model uses the Sabre ES9028 Pro chip and transmits in direct DSD
Ok my mistake.DSD Direct ≠ Native DSD.
DSD Direct refers to some DAC chips' ability to bypass the oversampling filter and ∆Σ Modulator for DSD audio, like what you can see here for the AK4493S:
As you can see in this block diagram, the ES9028Pro is not capable of DSD Direct:
I believe that is "DSD Direct".Native DSD just takes the bitstream and applies a lowpass filter only. Very minimalistic.
The number of FW update registrations on the SMSL website is small.Looking at their webpage, SMSL seem to issue considerably fewer firmware updates to their products than Topping. Either their devices are flawless out of the factory, or...(?)
Best price/performance ratio is tempting, but both HW longetivity and aftersale SW support is a question, if it is not "wiser" to pay a bit more.The number of FW update registrations on the SMSL website is small.
The reason is that FW updates are registered on HP for a certain period of time and then deleted. Also, with SMSL, FW updates themselves are not performed much in the first place. I don't know the reason, but it may be due to SMSL's corporate structure or company policy.
