Wow, this did the trick. Many thanks!mentamums,
put your tv, or apple box audio settings to PCM and that noise is gone. D30 will not decode dolby/dts signals.
Hi. So it work or not? Ive bought lately D03, works great but analog input is really downside of this amp. I want to fix this if there is a working solution.I'v noticed low quality of analog input. D03 use PCM1808 for ADC. Cheap adc, but it sounds preety good at Edifier Rxxxx multimedia speakers.
I'v measured ADC input filter components value. There is low pass filter with -3db frequency at 2.6kHz. That's the problem. Dont know, it is mistake from assembly line, or it's schematic mistake.
C145 capacitor should be ~2.4nF for LPF frequency at 24 kHz cause ADC work at 96kHz with limit of input audio frequency 48kHz.
Schematic for one channel, another channel similar, but several component have no marking on pcb. I'v removed C145 and similar capacitor from another channel. Analog input sounds good.
That is orignal ADC input LPF schematic. Have no pcb photo for showing that capacitors. I'll add photo later.
That doesn't have to be the amp's fault. I had those dropouts with a Loxjie A30, but only when optically connected to my Samsung TVs. If you google "Samsung TV optical dropouts" you'll find these dropouts occur with a wide variety of connected gear, so the fault probably lies with the TV.Hi, I have the same problem as @theurden (https://audiosciencereview.com/foru...mplifier-subjective-review.25686/post-1274460). Sometimes the sound is interrupted for a second or so and then comes back. The problem happens to me both via USB and Bluetooth with different audio sources (Spotify, Apple Music, Amazon Music or direct playback). I returned the first amplifier for this reason, and the second one that has just arrived to me has the same problem, so it seems to be a design problem of the amplifier.
Can you explain what menu system for sub?You need to set up the D03 using the menu system if you are going to use the Sub output.
Most important features are bluetooth and sub out. Would prefer something all in one.Well if you just want aux / RCA input go for the Fosi Audio V3 (or the Aiyima A07) maybe with a cheap SMSL DAC for your digital inputs?
Depending on what other features you are using ? E.g. Remote control? Tone controls?
AIYIMA D03 is a full digital amplifier, but it adds an analog input in addition to the digital input, but unfortunately its sound quality is not good. Think of the analog input as a bonus feature.Well if you just want aux / RCA input go for the Fosi Audio V3 (or the Aiyima A07) maybe with a cheap SMSL DAC for your digital inputs?
Yep, owned one, Bluetooth and digital inputs on the D03 are very good, the aux is not.What would you guys recommend as an alternative to this with similar features and price but with a decent RCA in?
I've been using my D03 exclusively over bluetooth for a year and have been very happy with how it sounds.
But I just recently wanted to connect a DJ controller to the aux input and wow does it sound like crap
You mean sub-out?I'm using the D03's analogue out
