Amazon Basics Optical Coax DAC Review
Rate this DAC:
    Votes: 84 41.8%
    Votes: 99 49.3%
    Votes: 17 8.5%
    Votes: 1 0.5%
This is a review and detailed measurements of the Amazon Basics "192 kHz" Toslink optical and Coax input DAC. I purchased it on member suggestion and costs US $14.
Amazon Basics 192KHz Digital Optical Coax to Analog RCA Audio Converter Review.jpg
Can't expect more given the price and functionality. As noted there are dual inputs (NO USB -- USB is for power only):
Amazon Basics 192KHz Digital Optical Coax to Analog RCA Audio Converter Review Input.jpg
An RCA to 3.5mm adapter cable is included presumably for headphone use.
It is interesting to see full regulatory certification and manufacturing in Vietnam:
Amazon Basics 192KHz Digital Optical Coax to Analog RCA Audio Converter Review FCC.jpg
I would think if it is just a rebranded generic DAC, it would have come from China.
Amazon Basics DAC Measurements
As usual, we start with our Dashboard, feeding the DAC a 1 kHz digital tone:
Amazon Basics 192KHz Digital Optical Coax to Analog RCA Audio Converter Measurement.png
I hoped for 96 dB but got 85 dB SINAD (relative sum of noise+distortion). This puts the unit solidly in the "poor" category of all DACs tested:
I was sad to see just 1 volt output. This definitely impacts any headphone listening and makes it less compatible with devices out there.
Noise floor is high by our standards but good enough for the target application:
Amazon Basics 192KHz Digital Optical Coax to Analog RCA Audio Converter Measurement Dynamic Ra...png
Someone forgot to enable the output filter (or implement one):
Amazon Basics 192KHz Digital Optical Coax to Analog RCA Audio Converter Measurement Filter.png
Low level linearity is lost due to noise:
Amazon Basics 192KHz Digital Optical Coax to Analog RCA Audio Converter Measurement Linearity.png
Intermodulation distortion vs level shows that it does do better at max volume than a typical (low performance) phone headphone dongle:
Amazon Basics 192KHz Digital Optical Coax to Analog RCA Audio Converter Measurement IMD.png
Jitter disturbances are quite low but that is likely due to very high noise floor hiding them:
Amazon Basics 192KHz Digital Optical Coax to Analog RCA Audio Converter Measuremen Jitter.png
The biggest issue was when I swept the digital input tone:
Amazon Basics 192KHz Digital Optical Coax to Analog RCA Audio Converter Measurement Distortion...png
The lack of filtering is the reason at high frequencies the graph goes off the chart (the green line at 96 kHz sampling reduces this impact). So we could "forgive" that but not the rise in low frequency distortion. SINAD drops to 50 at 20 Hz! Usually this is caused by poor power supply design. They have the room here to do a good job but obviously they did not to hit a cost target or didn't know better.
I tried to run the Multitone test which is at 192 kHz but could not get the unit to accept that over either Coax or Toslink. The mention of that in the product name is therefore improper. The DAC chip no doubt supports 192 kHz but there is no way to feed it such a digital signal.
There are some signs of quality here given the regulatory certifications and such. I am sure that was part of the product requirement doc (PRD) Amazon gave to whoever designed this. Sadly they did not know to specify other important bits related to fidelity, resulting in a device that clearly could have been better but is not. No doubt it spits out sound though so as a "throw away" product, it works.
In this site, my goal is to find best in class product and sadly, the Amazon Basics DAC is not it. As such, I cannot recommend it.
solderdude
The Neitherlands
It says... Vietnam on the device. ;)
I use the same one (not Amazon) so I can easily extract the audio from a Samsung TV which only has optical audio out to run it to some cheap active desktop speakers to get decent sound.
Once I had to unplug the power when one channel stops giving sound.:(
Other than that hey work fine otherwise and do their job. I don't think anyone will be using this as a serious DAC though.
Thanks for testing.
Multitone not measured ?
I voted fine... as it is fine for what it is intended to do at this price.
JSmith
Algol Perseus
Yeah this is the same as all those little converter boxes... this is just an Amazon re-badge of same, they wouldn't have had it designed at all.
Was also hoping for slightly better performance even at this price, however good to know these serve their purpose at the very least, but otherwise are worse than average in general. No hidden gem here.
JSmith
DanielT
Sweden - Слава Україні
Not horrible to my surprise! However, it still leaves a lot to be desired. I hope Amazon sees this and makes a version/mark 2.
I agree, just thought to write the same. Pretty close to an ok, I think.Or close or close. That is up to everyone to decide, the results are above.:)
Think about the price as well.
By the way. That was interesting! Thanks for the test Amir.:)
solderdude
The Neitherlands
Finally! Now the masses can experience the sublime delights of NOS!
:facepalm:
It oversamples so is not NOS (is a DS DAC) but does not have any digital filtering.
Only in produced ultrasonic crap it acts as a filterless NOS DAC but not in HF roll-off nor noise.
restorer-john
@amirm Test the D/A for DC offset. That will be what is throwing your THD vs Freq at the low end.
Most of those $10 D/As have no buffer or blocking capacitor and the output comes straight out of the D/A chip itself. The ones I tested had up to 0.5V offset on the L/R RCAs.
peanuts
there is so such thing as "china export" according to the EU
"The Commission responded that it was unaware of the existence of any "Chinese Export" mark and that, in its view, the misunderstanding had arisen because a producer had failed to respect the precise dimensions and proportions of the mark as prescribed in the legislation.[15] The Commission was also aware of fraudulent misuse of the mark on products that did not comply with the standards, but that this is a separate issue."
charleski
Manchester UK
The audiophile terminology is, unsurprisingly, imprecise and confusing. Any sort of resampling will, by definition, implement a filter, but the filter design (most importantly length) determines how competent it is (how much it rejects out-of-band signals). A decent modern DS DAC has several different stages of oversampling that implement different filters, as seen in fig 18.8 from Pohlman's book:
It's the first oversampling block that performs the alias-rejection filtering (and typically some noise-shaping). In terms of the history of digital audio, such oversampling was introduced very early with R2R DACs. The venerable TDA1541 that pops up is so many 'NOS' designs was actually designed to be used with the SAA7220 digital filter, which oversampled to 176kHz. But the SAA7220 had a lot of problems with jitter due to coupling between the clock and filter supplies and some designers stumbled on the bright idea of ripping it out completely. And boom, 'NOS' was born. There's a DAC design on DIYAudio that implements a 'NOS' DAC using a delta-sigma chip by bypassing the integrated first-stage filter. Obviously oversampling is happening further down the line, but it replicates the conceptual basis, though it's only interesting as a demonstration. A sigma-delta DAC that doesn't have a proper oversampling/shaped filter will display quantisation noise rising at 6dB/octave, which seems very close to what Amir showed here, so I suspect they're doing something similar.
Of course retro-tech audiophiles tend to go all-in on their obsession with obsolete technology, and most these days would insist that a 'NOS' DAC has to be R2R as well. This one probably wouldn't pass muster as providing the true, magical 'NOS' sound, but frankly I find it difficult to care.
solderdude
The Neitherlands
respice finem
I gave it a "not terrible", since the purpose of these is mostly to get TV sound from Toslink out to an analog amp, or a pair of mostly cheap active speakers. The lack of USB in doesn't matter either for this purpose.
