ApplePi DAC w/ Volume-Clocker Measurements
orchardaudio
Succasunna, NJ
I just wanted to make a comprehensive post of all measurements, of the ApplePi DAC and Volume-Clocker combo.
SNR A-Weighted (XLR):
SNR no-weighting (XLR):
SINAD (XLR):
Dynamic Range A-Weighted (XRL):
Dynamic Range no-weighting (XRL):
THD+N vs Level (XLR):
IMD vs Level (XRL):
Frequency Response (XLR):
THD+N vs Frequency (XRL):
Linearity (XLR):
Jitter (XRL) - 256k FFT with 16 averages:
Crosstalk (XLR):
If there is something else that you need please post and I will update.
derp1n
Measurements without a-weighting.
pos
That would be the Gala DAC...
@orchardaudio, could we get the same kind of measurements for the Gala? (including measurements with the SRC chip physically bypassed if possible, especially the jitter one)
restorer-john
Orchard, I suspect your frequency steps on the AP are perhaps too coarse at the end of the FR test. I cannot believe the D/A would be -6dB at 20KHz.
When are you going to update the specifications on your website to reflect the actual results your products can achieve?
Grave
107.5, 109.5. That's a 2 dB difference in SINAD between channels, weird.
orchardaudio
orchardaudio
Succasunna, NJ
you are correct it is just a number of steps, that is the issue.
Here it is with more steps:
