somebodyelse
- Joined
- Dec 5, 2018
- Messages
- 3,780
- Likes
- 3,090
I've got one too, and there are several other SigmaDSP options out there - 3E (as measured here), Auverdion/FreeDSP, Sure/Wondom/Dayton, and odd dev boards from ebay, ali and the like. My biggest problem is that, like hypex, SigmaStudio needs Windows if you want to do low level stuff. HifiBerry and Auverdion have done some good work in providing a lot of control without SigmaStudio, but they need a DSP program for a fixed hardware interface to do it.I use the HifiBerry DAC + DSP to get more channels. It works pretty well, but obviously, you cannot do more than two channels of software filtering on the PI. The DSP is quite capable however, as long as you don't need any high tap count FIR it will do for most people. Also would love to see one or two extra SPDIF output (they can be hacked on though).
Custom firmware for the Tone Board to make use of its I2S/TDM expansion connector is another option...
To be fair it's at least partly incomplete implementation in the kernel UAC2 drivers too - 5.12 has just seen some patches to improve implicit feedback support, including some from a MOTU employee which might be a first. Unfortunately that's related to the M series interfaces, not the AVB ones which would be more suitable - but perhaps they'll move on to sorting out their compatibility next?Yeah, blame the manufacturers Some of the Pro interfaces have proprietary drivers and do not offer Linux support. It would definitely be good to have a list of such devices!
Even if the drivers were sorted we come back to the price - there aren't many interfaces with 6 or 8 output channels that cost much less than a pair of FA123s. The ESI Gigaport eX is worth a look, but I'd like balanced outputs. If only there was an 8 channel version of the D10nda or the Tone2...
We're into the 'proprietary compatibility' issue again - if companies won't share APIs we're left with reverse engineering, closed solutions or less convenient workarounds.Tidal integration is poor. On line streaming is the only music source for some members.
