ASR Open Source Streamer Project
mdsimon2
Detroit, MI
I’ve used both the USB2 and USB3 type A slots on the RPi4, have not used the type C connection. If I used the type C slot I assume I would need to provide 5 V power to the pin header?
I did wonder if I would get anything different using a USB card in the PCIe slot but they all were way too tall to fit in a 1RU enclosure so I didn’t give it much thought.
Michael
Madjalapeno
NH, USA
Yeah, would have been nice if it would have worked. Have you used yours successfully with a USB DAC? I have MOTU M4 which seems much more flexible than the Mk5 so I might try it down the line with the CM4.
Michael
I had it running DietPi, streaming from Roon to a Topping E30 for about 10 minutes as a sanity check.
I'm going to try it with a Topping A10s (when Amazon delivers it today), and will give it a longer test. Will need to create a new sd card for it as seem to be getting through them at the moment, so will try Ubuntu Server for you too.
phofman
All type A USB ports on RPi4 are connected to the onboard VL805 PCI-e USB controller. Please can you check the dwc2 USB-C controller instead? Yes you will have to power your Pi through the pinheader. Thanks.
mdsimon2
Detroit, MI
Interestingly enough the RPi4 does not recognize the Mk5 at all through the USB C slot (does not show up when I run lsusb). As I do not usually use a USB C cable with the MK5 I also tried it with a macbook pro and that worked fine.
Michael
mdsimon2
Detroit, MI
phofman
M4 required a quirk to the kernel to enable its implicit feedback async control. Maybe Mk5 will need the same for clean playback. But the failed enumeration must be a different problem. Please can you post dmesg output after plugging the Mk5 to the USB-C port? Just dmesg -w and copy what appeared after plugging the card in. Also lsusb -v output for the Mk5 through the working USB2 (not USB3) ports (the configuration reported by the card should be same for any USB2 port, be it USB-A or USB-C). Thanks.
mdsimon2
Detroit, MI
I tried to run the diagnostics you requested but ran in to an issue when trying to use the USB C port on the RPi4 because there is no change in dmesg when I plug the Ultralite Mk5 in. I again tried plugging the M4 and that does show up in dmesg as does using the Mk5 on a USB 2 port. I also ran the same diagnostics on the CM4. I do not have the expertise to interpret the reports but see below.
MOTU Ultralite Mk5 - RPi4 - Ubuntu Server 64 bit 21.10 - USB 2 - lsusb -v
Code:
Bus 001 Device 003: ID 07fd:000c Mark of the Unicorn UltraLite-mk5
Couldn't open device, some information will be missing
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceClass          239 Miscellaneous Device
  bDeviceSubClass         2
  bDeviceProtocol         1 Interface Association
  bMaxPacketSize0        64
  idVendor           0x07fd Mark of the Unicorn
  idProduct          0x000c
  bcdDevice            2.00
  iManufacturer           1 MOTU
  iProduct                2 UltraLite-mk5
  iSerial                 3 0001f2fffefff074
  bNumConfigurations      1
  Configuration Descriptor:
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0259
    bNumInterfaces          8
    bConfigurationValue     1
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              100mA
    Interface Association:
      bLength                 8
      bDescriptorType        11
      bFirstInterface         0
      bInterfaceCount         5
      bFunctionClass          1 Audio
      bFunctionSubClass       0
      bFunctionProtocol      32
      iFunction               0
    Interface Descriptor:
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         1 Audio
      bInterfaceSubClass      1 Control Device
      bInterfaceProtocol     32
      iInterface              0
      AudioControl Interface Descriptor:
        bLength                 9
        bDescriptorType        36
        bDescriptorSubtype      1 (HEADER)
        bcdADC               2.00
        bCategory               8
        wTotalLength       0x0053
        bmControls           0x00
        bLength                 8
        bDescriptorType        36
        bDescriptorSubtype     10 (CLOCK_SOURCE)
        bClockID                2
        bmAttributes            0 External clock
        bmControls           0x07
          Clock Frequency Control (read/write)
          Clock Validity Control (read-only)
        bAssocTerminal          0
        iClockSource            5
        bLength                 8
        bDescriptorType        36
        bDescriptorSubtype     11 (CLOCK_SELECTOR)
        bClockID                1
        bNrInPins               1
        baCSourceID(0)          2
        bmControls           0x00
        iClockSelector          0
        bLength                17
        bDescriptorType        36
        bDescriptorSubtype      2 (INPUT_TERMINAL)
        bTerminalID             3
        wTerminalType      0x0101 USB Streaming
        bAssocTerminal          0
        bCSourceID              1
        bNrChannels            22
        bmChannelConfig    0x00000000
        iChannelNames          10
        bmControls         0x0000
        iTerminal               9
        bLength                12
        bDescriptorType        36
        bDescriptorSubtype      3 (OUTPUT_TERMINAL)
        bTerminalID             4
        wTerminalType      0x0602 Digital Audio Interface
        bAssocTerminal          0
        bSourceID               3
        bCSourceID              1
        bmControls         0x0000
        iTerminal               0
        bLength                17
        bDescriptorType        36
        bTerminalID             6
        bAssocTerminal          0
        bCSourceID              1
        bNrChannels            20
        iChannelNames          32
        bmControls         0x0000
        iTerminal               8
        bLength                12
        bDescriptorType        36
        bTerminalID             5
        bAssocTerminal          0
        bSourceID               6
        bCSourceID              1
        bmControls         0x0000
        iTerminal               0
      Endpoint Descriptor:
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x81  EP 1 IN
        bmAttributes            3
          Transfer Type            Interrupt
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0006  1x 6 bytes
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceSubClass      2 Streaming
      iInterface              8
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              8
      AudioStreaming Interface Descriptor:
        bLength                16
        bDescriptorType        36
        bDescriptorSubtype      1 (AS_GENERAL)
        bTerminalLink           3
        bmControls           0x05
          Active Alternate Setting Control (read-only)
          Valid Alternate Setting Control (read-only)
        bFormatType             1
        bmFormats          0x00000001
          PCM
        bNrChannels            22
        iChannelNames           0
        bLength                 6
        bDescriptorType        36
        bDescriptorSubtype      2 (FORMAT_TYPE)
        bFormatType             1 (FORMAT_TYPE_I)
        bSubslotSize            3
        bBitResolution         24
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x02  EP 2 OUT
        bmAttributes            5
          Transfer Type            Isochronous
          Synch Type               Asynchronous
          Usage Type               Data
        wMaxPacketSize     0x01ce  1x 462 bytes
        bInterval               1
        AudioStreaming Endpoint Descriptor:
          bLength                 8
          bDescriptorType        37
          bDescriptorSubtype      1 (EP_GENERAL)
          bmAttributes         0x00
          bmControls           0x00
          bLockDelayUnits         0 Undefined
          wLockDelay         0x0000
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       2
      bNumEndpoints           1
      iInterface              8
        bLength                16
        bDescriptorType        36
        bTerminalLink           3
        bmControls           0x05
        bFormatType             1
          PCM
        bNrChannels            18
        iChannelNames           0
        bLength                 6
        bDescriptorType        36
        bSubslotSize            3
        bBitResolution         24
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x02be  1x 702 bytes
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay         0x0000
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       3
      bNumEndpoints           1
      iInterface              8
        bLength                16
        bDescriptorType        36
        bTerminalLink           3
        bmControls           0x05
        bFormatType             1
          PCM
        bNrChannels            10
        iChannelNames           0
        bLength                 6
        bDescriptorType        36
        bSubslotSize            3
        bBitResolution         24
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        wMaxPacketSize     0x02ee  1x 750 bytes
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay         0x0000
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           0
      iInterface              9
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              9
        bLength                16
        bDescriptorType        36
        bTerminalLink           5
        bmControls           0x05
        bFormatType             1
          PCM
        bNrChannels            20
        iChannelNames           0
        bLength                 6
        bDescriptorType        36
        bSubslotSize            3
        bBitResolution         24
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x83  EP 3 IN
        bmAttributes           37
          Usage Type               Implicit feedback Data
        wMaxPacketSize     0x01a4  1x 420 bytes
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay         0x0000
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       2
      bNumEndpoints           1
      iInterface              9
        bLength                16
        bDescriptorType        36
        bTerminalLink           5
        bmControls           0x05
        bFormatType             1
          PCM
        bNrChannels            16
        iChannelNames           0
        bLength                 6
        bDescriptorType        36
        bSubslotSize            3
        bBitResolution         24
        bLength                 7
        bDescriptorType         5
        bmAttributes           37
        wMaxPacketSize     0x0270  1x 624 bytes
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay         0x0000
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       3
      bNumEndpoints           1
      iInterface              9
        bLength                16
        bDescriptorType        36
        bTerminalLink           5
        bmControls           0x05
        bFormatType             1
          PCM
        bNrChannels            10
        iChannelNames           0
        bLength                 6
        bDescriptorType        36
        bSubslotSize            3
        bBitResolution         24
        bLength                 7
        bDescriptorType         5
        bmAttributes           37
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay         0x0000
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceProtocol      0
      iInterface              0
        bLength                 9
        bDescriptorType        36
        bcdADC               1.00
        wTotalLength       0x0009
        bInCollection           1
        baInterfaceNr(0)        1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        4
      bAlternateSetting       0
      bNumEndpoints           2
      bInterfaceSubClass      3 MIDI Streaming
      iInterface              0
      MIDIStreaming Interface Descriptor:
        bLength                 7
        bDescriptorType        36
        bcdADC               1.00
        wTotalLength       0x0041
        bLength                 6
        bDescriptorType        36
        bDescriptorSubtype      2 (MIDI_IN_JACK)
        bJackType               1 Embedded
        bJackID                 1
        iJack                   0
        bLength                 6
        bDescriptorType        36
        bJackType               2 External
        bJackID                 2
        iJack                  11
        bLength                 9
        bDescriptorType        36
        bDescriptorSubtype      3 (MIDI_OUT_JACK)
        bJackID                 3
        bNrInputPins            1
        baSourceID( 0)          2
        BaSourcePin( 0)         1
        iJack                   0
        bLength                 9
        bDescriptorType        36
        bJackID                 4
        bNrInputPins            1
        baSourceID( 0)          1
        BaSourcePin( 0)         1
        iJack                  10
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x08  EP 8 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0200  1x 512 bytes
        bInterval               0
        MIDIStreaming Endpoint Descriptor:
          bLength                 5
          bDescriptorType        37
          bDescriptorSubtype      1 (GENERAL)
          bNumEmbMIDIJack         1
          baAssocJackID( 0)       1
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x89  EP 9 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
          bLength                 5
          bDescriptorType        37
          bNumEmbMIDIJack         1
          baAssocJackID( 0)       3
      bLength                 8
      bDescriptorType        11
      bFirstInterface         5
      bInterfaceCount         2
      bFunctionClass          2 Communications
      bFunctionSubClass       6 Ethernet Networking
      bFunctionProtocol       0
      iFunction               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        5
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass         2 Communications
      bInterfaceSubClass      6 Ethernet Networking
      iInterface              0
      CDC Header:
        bcdCDC               10.01
      CDC Ethernet:
        iMacAddress                      4 (??)
        bmEthernetStatistics    0x00000000
        wMaxSegmentSize               1522
        wNumberMCFilters            0x0000
        bNumberPowerFilters              0
      CDC Union:
        bMasterInterface        5
        bSlaveInterface         6
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x84  EP 4 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0040  1x 64 bytes
        bInterval              10
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        6
      bAlternateSetting       0
      bNumEndpoints           0
      bInterfaceClass        10 CDC Data
      bInterfaceSubClass      0
      iInterface              0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        6
      bAlternateSetting       1
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x05  EP 5 OUT
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x86  EP 6 IN
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
      bLength                 8
      bDescriptorType        11
      bFirstInterface         7
      bInterfaceCount         1
      bFunctionClass        255 Vendor Specific Class
      bFunctionSubClass       0
      bFunctionProtocol       0
      iFunction               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        7
      bAlternateSetting       0
      bNumEndpoints           1
      bInterfaceClass       255 Vendor Specific Class
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bEndpointAddress     0x87  EP 7 IN
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        wMaxPacketSize     0x0080  1x 128 bytes
        bInterval               2
MOTU Ultralite Mk5 - RPi 4 - Ubuntu Server 64 bit 21.10 - USB 2 - dmesg -w
Code:
[  180.679405] usb 1-1.4: new high-speed USB device number 3 using xhci_hcd
[  180.784346] usb 1-1.4: New USB device found, idVendor=07fd, idProduct=000c, bcdDevice= 2.00
[  180.784376] usb 1-1.4: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  180.784393] usb 1-1.4: Product: UltraLite-mk5
[  180.784407] usb 1-1.4: Manufacturer: MOTU
[  180.784419] usb 1-1.4: SerialNumber: 0001f2fffefff074
[  180.856143] cdc_ether 1-1.4:1.5 eth1: register 'cdc_ether' at usb-0000:01:00.0-1.4, CDC Ethernet Device, 00:01:f2:ff:f0:75
[  180.856294] usbcore: registered new interface driver cdc_ether
[  180.900563] usbcore: registered new interface driver snd-usb-audio
[  180.950153] cdc_ether 1-1.4:1.5 enx0001f2fff075: renamed from eth1
MOTU M4 - RPi 4 - Ubuntu Server 64 bit 21.10 - USB C - dmesg -w
Code:
[  298.004187] usb 3-1: new high-speed USB device number 2 using dwc2
[  298.212786] usb 3-1: New USB device found, idVendor=07fd, idProduct=0008, bcdDevice= 1.02
[  298.212817] usb 3-1: New USB device strings: Mfr=1, Product=3, SerialNumber=2
[  298.212834] usb 3-1: Product: M4
[  298.212848] usb 3-1: Manufacturer: MOTU
[  298.212861] usb 3-1: SerialNumber: M40000058933
MOTU Ultralite Mk5 - CM4 - Ubuntu Server 64 bit 21.10 - USB 2 - dmesg -w
Code:
[  140.299518] usb 1-1.1: new high-speed USB device number 3 using dwc2
[  140.400565] usb 1-1.1: New USB device found, idVendor=07fd, idProduct=000c, bcdDevice= 2.00
[  140.400604] usb 1-1.1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[  140.400621] usb 1-1.1: Product: UltraLite-mk5
[  140.400635] usb 1-1.1: Manufacturer: MOTU
[  140.400648] usb 1-1.1: SerialNumber: 0001f2fffefff074
[  140.481137] cdc_ether 1-1.1:1.5 eth1: register 'cdc_ether' at usb-fe980000.usb-1.1, CDC Ethernet Device, 00:01:f2:ff:f0:75
[  140.485587] usbcore: registered new interface driver cdc_ether
[  140.517523] usbcore: registered new interface driver snd-usb-audio
[  140.551466] cdc_ether 1-1.1:1.5 enx0001f2fff075: renamed from eth1
MOTU Ultralite MK5 - CM4 - Ubuntu Server 64 bit 21.10 - lsusb -v
Code:
Device Descriptor:
  bLength                18
  bDescriptorType         1
  bcdUSB               2.00
  bDeviceSubClass         2
  bMaxPacketSize0        64
  idProduct          0x000c
  bcdDevice            2.00
    bLength                 9
    bDescriptorType         2
    wTotalLength       0x0259
    bNumInterfaces          8
    iConfiguration          0
    bmAttributes         0x80
      (Bus Powered)
    MaxPower              100mA
      bLength                 8
      bDescriptorType        11
      bFirstInterface         0
      bInterfaceCount         5
      bFunctionSubClass       0
      iFunction               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        0
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 9
        bDescriptorType        36
        bcdADC               2.00
        bCategory               8
        wTotalLength       0x0053
        bmControls           0x00
        bLength                 8
        bDescriptorType        36
        bClockID                2
        bmControls           0x07
        bAssocTerminal          0
        iClockSource            5
        bLength                 8
        bDescriptorType        36
        bClockID                1
        bNrInPins               1
        baCSourceID(0)          2
        bmControls           0x00
        iClockSelector          0
        bLength                17
        bDescriptorType        36
        bTerminalID             3
        bAssocTerminal          0
        bCSourceID              1
        bNrChannels            22
        iChannelNames          10
        bmControls         0x0000
        iTerminal               9
        bLength                12
        bDescriptorType        36
        bTerminalID             4
        bAssocTerminal          0
        bSourceID               3
        bCSourceID              1
        bmControls         0x0000
        iTerminal               0
        bLength                17
        bDescriptorType        36
        bTerminalID             6
        bAssocTerminal          0
        bCSourceID              1
        bNrChannels            20
        iChannelNames          32
        bmControls         0x0000
        iTerminal               8
        bLength                12
        bDescriptorType        36
        bTerminalID             5
        bAssocTerminal          0
        bSourceID               6
        bCSourceID              1
        bmControls         0x0000
        iTerminal               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       0
      bNumEndpoints           0
      iInterface              8
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              8
        bLength                16
        bDescriptorType        36
        bTerminalLink           3
        bmControls           0x05
        bFormatType             1
          PCM
        bNrChannels            22
        iChannelNames           0
        bLength                 6
        bDescriptorType        36
        bSubslotSize            3
        bBitResolution         24
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay         0x0000
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       2
      bNumEndpoints           1
      iInterface              8
        bLength                16
        bDescriptorType        36
        bTerminalLink           3
        bmControls           0x05
        bFormatType             1
          PCM
        bNrChannels            18
        iChannelNames           0
        bLength                 6
        bDescriptorType        36
        bSubslotSize            3
        bBitResolution         24
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay         0x0000
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        1
      bAlternateSetting       3
      bNumEndpoints           1
      iInterface              8
        bLength                16
        bDescriptorType        36
        bTerminalLink           3
        bmControls           0x05
        bFormatType             1
          PCM
        bNrChannels            10
        iChannelNames           0
        bLength                 6
        bDescriptorType        36
        bSubslotSize            3
        bBitResolution         24
        bLength                 7
        bDescriptorType         5
        bmAttributes            5
          Usage Type               Data
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay         0x0000
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       0
      bNumEndpoints           0
      iInterface              9
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       1
      bNumEndpoints           1
      iInterface              9
        bLength                16
        bDescriptorType        36
        bTerminalLink           5
        bmControls           0x05
        bFormatType             1
          PCM
        bNrChannels            20
        iChannelNames           0
        bLength                 6
        bDescriptorType        36
        bSubslotSize            3
        bBitResolution         24
        bLength                 7
        bDescriptorType         5
        bmAttributes           37
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay         0x0000
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       2
      bNumEndpoints           1
      iInterface              9
        bLength                16
        bDescriptorType        36
        bTerminalLink           5
        bmControls           0x05
        bFormatType             1
          PCM
        bNrChannels            16
        iChannelNames           0
        bLength                 6
        bDescriptorType        36
        bSubslotSize            3
        bBitResolution         24
        bLength                 7
        bDescriptorType         5
        bmAttributes           37
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay         0x0000
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        2
      bAlternateSetting       3
      bNumEndpoints           1
      iInterface              9
        bLength                16
        bDescriptorType        36
        bTerminalLink           5
        bmControls           0x05
        bFormatType             1
          PCM
        bNrChannels            10
        iChannelNames           0
        bLength                 6
        bDescriptorType        36
        bSubslotSize            3
        bBitResolution         24
        bLength                 7
        bDescriptorType         5
        bmAttributes           37
        bInterval               1
          bLength                 8
          bDescriptorType        37
          bmAttributes         0x00
          bmControls           0x00
          wLockDelay         0x0000
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        3
      bAlternateSetting       0
      bNumEndpoints           0
      iInterface              0
        bLength                 9
        bDescriptorType        36
        bcdADC               1.00
        wTotalLength       0x0009
        bInCollection           1
        baInterfaceNr(0)        1
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        4
      bAlternateSetting       0
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType        36
        bcdADC               1.00
        wTotalLength       0x0041
        bLength                 6
        bDescriptorType        36
        bJackID                 1
        iJack                   0
        bLength                 6
        bDescriptorType        36
        bJackID                 2
        iJack                  11
        bLength                 9
        bDescriptorType        36
        bJackID                 3
        bNrInputPins            1
        baSourceID( 0)          2
        BaSourcePin( 0)         1
        iJack                   0
        bLength                 9
        bDescriptorType        36
        bJackID                 4
        bNrInputPins            1
        baSourceID( 0)          1
        BaSourcePin( 0)         1
        iJack                  10
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
          bLength                 5
          bDescriptorType        37
          bNumEmbMIDIJack         1
          baAssocJackID( 0)       1
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
          bLength                 5
          bDescriptorType        37
          bNumEmbMIDIJack         1
          baAssocJackID( 0)       3
      bLength                 8
      bDescriptorType        11
      bFirstInterface         5
      bInterfaceCount         2
      bFunctionProtocol       0
      iFunction               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        5
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
      CDC Header:
        bcdCDC               10.01
      CDC Ethernet:
        iMacAddress                      4 (??)
      CDC Union:
        bMasterInterface        5
        bSlaveInterface         6
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval              10
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        6
      bAlternateSetting       0
      bNumEndpoints           0
      iInterface              0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        6
      bAlternateSetting       1
      bNumEndpoints           2
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
        bLength                 7
        bDescriptorType         5
        bmAttributes            2
          Transfer Type            Bulk
          Synch Type               None
          Usage Type               Data
        bInterval               0
      bLength                 8
      bDescriptorType        11
      bFirstInterface         7
      bInterfaceCount         1
      bFunctionSubClass       0
      bFunctionProtocol       0
      iFunction               0
      bLength                 9
      bDescriptorType         4
      bInterfaceNumber        7
      bAlternateSetting       0
      bNumEndpoints           1
      iInterface              0
        bLength                 7
        bDescriptorType         5
        bmAttributes            3
          Synch Type               None
          Usage Type               Data
        bInterval               2
Michael
phofman
Thanks for the dumps. The Mk5 config is huge but that should not matter should everything work correctly, just like it does not matter on other USB controllers. The fact is the VL805 PCI-e USB controller in RPi4 is USB3 (xhci) but theoretically it should make no difference plus you tested on the USB2 ports. Please can you test Mk5 on linux on some other device with native USB2 ports (some older x86 device)?
I wonder why the enumeration in RPi4 dwc2 fails. Please are you able to make a dump of USB packets with wireshark? https://wiki.wireshark.org/CaptureSetup/USB#Linux - no need to hassle with the user permissions, just run wireshark directly under root (sudo). Ideally dumping the working VL805 enumeration communication and the failing dwc2 communication. The USB port to pick in wireshark is listed in lsusb - to learn which is used by dwc2 just connect any working USB device to the USB-C port. Once we have the packets, we can ask at the linux-usb mailing list. Thanks a lot.
Also one option - can you try raspbian instead of the Ubuntu? The mainline kernel DTS files for RPi4 are configured a bit differently than those in raspbian, maybe there is the problem, not so many people test the Ubuntu option.
The Mk5 will need also some quirk for the implicit feedback (like M4) but that would come as second step.
mdsimon2
Detroit, MI
Unfortunately I do not have any x86 devices with USB 2 ports. I actually just recycled 2 older laptops running linux last weekend and now every computer I have only has native USB 3 ports.
Should be able to get everything else you requested this evening.
Michael
mdsimon2
Detroit, MI
I tried to use wireshark but it looks GUI based and all my RPIs do not have a desktop installed. I did try x forwarding over SSH but that did not seem to work.
I can certainly install a desktop if necessary but would prefer not to if it can be avoided. Are there any other options?
Michael
Honken
Scania
First of all, thanks for taking the time and effort to debug this.
I believe that you can use tshark to capture USB interface dumps from headless devices, and then analyze the dump file with the GUI version. I say believe as I haven't had to dump USB traffic with tshark previously, only network traffic.
voodooless
Netherlands
Usually you can just make a capture file, copy it over and open it in the gui.
dc655321
Michael
Try tshark - cmdline version
mdsimon2
Detroit, MI
Ok, did some tshark captures and also tried using Raspberry Pi OS.
Raspberry Pi OS was less successful than Ubuntu, Ultralite Mk5 was again NOT recognized through USB C of a RPi4 and I could not get anything to play to Ultralite on the RPi4 or CM4. Another oddity is that when I plugged in the Ultralite to both the CM4 and RPi4 the network connection would go out, this happened for both ethernet and wifi.
I made a variety of tshark captures, for the CM4 and RPi4 running Ubuntu I was streaming music to the Mk5 when I made the capture which made the captures quite large, all other captures had the Ultralite connected to the Pi but nothing playing (as I could not get anything to play to Ultralite in these cases).
Due to the size of the captures I had to host these externally, see link below.
I should also say that I am quite happy using the RPi4 and Ubuntu with the Ultralite, I have had no issues so far. I am happy to help troubleshoot if it helps others but I do not have a personal need to get the CM4 or the USB C of the RPi4 working with the Ultralite.
On a more positive note I received the thinner OLED display this week and have been playing around with layout. See attached for some first attempts. Think I will make the volume just a bit smaller and double the size of the text on the left hand side of the screen as it is too hard to read from more than a few feet away. But overall the display looks nice and will fit perfectly in a 1RU enclosure.
Michael
phofman
Hi Michael,
Thanks for the dumps. I am a bit lost:
CM4 dumps:
usbmon1-cm4-ubuntu-usb2.pcap:
The enumeration of device 1.3 started while isochronous transfers in/out from that device (capture/playback) were running. How did you achieve that? Please can you send packets of the initial enumeration, starting packet capture before plugging the device in?
usbmon1-cm4-raspbian-usb2.pcap:
No CONFIGURATION packets are listed, only initial DEVICE ones. Even for the linux root hub and the onboard Microchip USB hub. That's weird, did you perhaps apply some filter while capturing?
RPi4 dumps for USB-C (dwc2):
usbmon3-rpi4-ubuntu-usbc.pcap:
Only the linux root hub (3.1) is listed, no other device. The host keeps asking the Root hub for status and the hub responds with C_PORT_SUSPEND. Was the soundcard actually connected? Did you check the cable?
usbmon3-rpi4-raspian-usbc.pcap:
Also empty, as if no device was actually connected.
The Ultralite is a composite device with integrated usb-ethernet device. Probably for configuring the device via a web interface (I plan the same setup for my usb-gadget project). Either the kernel got stuck at error and RPi froze (that would require connecting a monitor), or the new network device overtook the network settings and default gateway was routed through the new network device (controlled by network-manager).
mdsimon2
Detroit, MI
Thanks for the feedback.
I did not know what I was doing with these captures so in general I followed the instructions here -> https://fedoraproject.org/wiki/Usbmon and was running "tshark -i usbmon2 -w /var/tmp/usbmon2.pcap" for the Ultralite bus as identified by running lsusb.
For the USB C cases I was unsure of what bus I should use because the Ultralite does not show up in lsusb so I plugged in the M4 to USB C and used the bus identified by lsusb.
For the captures made when playing music I was streaming to an ALSA loopback using shairport-sync and using CamillaDSP with the loopback as capture device and the Ultralite as playback device.
I am happy to re-run the captures before plugging in the Ultralite. After plugging in the Ultralite should I play something to it? I would prefer not to run the captures with Raspian because I cannot do this headless as a result of the network issues.
Michael
SDX-LV
Sweden
Sorry for not reading through the whole topic, but is it possible to have Replay Gain (like in Foobar2000) in a streamer that reads music from USB or NAS? :) I do not use Volumio in my miniDSP because it has no Replay Gain. I refuse to listen to music that jumps +/- 10dB from track to track - I better turn on my PC with Foobar than to accept such a downgrade.
mdsimon2
Detroit, MI
I've been working on the layout of the case and am in need of some community input. :)
A key aspect of the streamer to me is integration of an IR receiver for volume control via CamillaDSP. I've been using a FLIRC USB IR receiver for this and it works great and is very easy to set up. However I have not found an elegant solution for locating the IR receiver on the front of the chassis. Below is what I've thought through currently, would love to hear if anyone has a nice solution that I have not thought of (or if anyone has a preference for any of the solutions listed below).
Option 1 - FLIRC receiver in rear of case. I've had good luck bouncing IR signals off a wall behind the RPi and imagine that this will work in many circumstances. Downside is I am sure there are some configurations where this will be unreliable but there is always the option of adding an IR extender as well.
Option 2 - Locate RPi in center of case and use USB/LAN panel mount extenders (like this) to enable use of 3 USB ports in rear of case and 1 USB port in front of case (for IR receiver). This adds cost and additional complexity to the build and overall the solution feels inelegant. I do like that it will probably be easier to build because RPi placement will be more flexible.
Option 3 - Install a panel mount USB port in rear of case that then connects to a panel mount USB port in front of case (for IR receiver). A short USB cable could then be used to jumper between a USB port on the RPi and the panel mount USB port. Again this feels like a hack and I do not like the idea of running wires externally.
At this point I am leaning towards option 1 but am considering option 2. Any thoughts?
Michael
All the fussing around with the USB C port on the RPi4 made me realize there is a simple solution to this problem. Seems like I should be able to use the USB C port for the FLIRC IR receiver with a simple USB C to A adapter / extension. Of course this will require me to power the RPi from the pin header but I do not see an issue with that, will add a 5.5 mm power jack to the rear. Have an adapter / extension on the way from adafruit to test it out.
Michael
