Audioengine A5+ Powered Speaker Review
This is a review and detailed measurements of the Audioengine A5+ powered bookshelf speaker. It is the one without the bluetooth which seems to have slightly different design (centered tweeter versus not). It was kindly loaned to me by a member and costs US $399 including Prime shipping from Amazon.
The A5+ is a hefty little speaker with very nice gloss finish:
A remote control is included for simple functions (volume, mute, etc.). The business end is in the back:
Audioengine A5+ Powered desktop monitor speaker back panel connectors inputs outputs usb Audio...jpg
Unlike many budget powered monitors, the A5+ uses a linear power supply internally (as opposed to a laptop sized external power supply) which I appreciated it. It also eschews class D amps for traditional class AB amplification, hence the large heat sink in the back.
The crossover is passive by the way. This may be responsible for total lack of noise/hiss from the tweeter even when I put my ear next to it. A great benefit compared to a number of monitors which have annoying (but usually low level) hiss.
The slotted port is something I like as otherwise it can be annoying to have air pumped at your face when playing loud.
I should end this intro by saying that I have hardly had a good experience listening to these speakers at shows. They usually put them on a table chest high and play tracks on them which don't sound good to me.
Spinorama Audio Measurements
Acoustic measurements can be grouped in a way that can be perceptually analyzed to determine how good a speaker can be used. This so called spinorama shows us just about everything we need to know about the speaker with respect to tonality and some flaws:
Audioengine A5+ Powered desktop monitor speaker CEA-2034 Spinorama Frequency Response Audio Me...png
Most important curve here is the on-axis (or listening window) which shows pretty flat (for speakers) response sans a wide valley around upper bass. Whether that is on purpose and part of the amplification EQ or design of the speaker, I don't know. But I take higher bass output when I can have it as I can always turn that down.
We see some peaks in on-axis which survive when measured all around the speaker as indicated in blue and red curves, indicating resonances.
I can't find the crossover spec but would guess around 2.5 to 3 kHz. Around that region we find that off and on-axis responses don't quite match as well as they do elsewhere. There is a waveguide but perhaps is not fully optimized.
Early reflections in a room that are loudest and hence most influential in tonality we hear is not bad:
Audioengine A5+ Powered desktop monitor speaker CEA-2034 Spinorama Early Window Frequency Resp...png
Putting it all together, we get a pretty good response in a hypothetical average listening room:
Audioengine A5+ Powered desktop monitor speaker CEA-2034 Spinorama Predicted In-room Frequency...png
The only issue is that recessed upper bass making for an interesting test case of how important that region is.
Distortion tests show that we have a problem around 800 to 900 Hz region:
Audioengine A5+ Powered desktop monitor speaker THD Distortion Percentage Audio Measurement.png
Problem is there even at 86 dB (left side). We can see the issue in the context of overall response:
Audioengine A5+ Powered desktop monitor speaker THD Distortion Audio Measurement.png
I accept distortion/noise in low frequencies but like to see none in the above calibrated graph above that region.
As an aside, as indicated on the graph, these are "in-room" measurements that are then corrected to remove the effect of the room. As such, the graph is free of room modes which corrupts distortion measurements.
The CSD/Waterfall is created thee same way and seems to show the same problematic frequencies:
Audioengine A5+ Powered desktop monitor speaker CSD Waterfall Audio Measurement.png
Horizontal directivity plot shows reasonable response in that axis with rather smooth and broad response off-axis:
Audioengine A5+ Powered desktop monitor speaker Horizontal Directivity Audio Measurement.png
Here is a new way to look at the same but just with equal level contours:
Audioengine A5+ Powered desktop monitor speaker Horizontal Beamwidth Audio Measurement.png
The red line is the frequency at which we drop -6 dB. We see that we have better than +-55 degrees before that happens. That gives more freedom to move left and right without the tonality to shift. Given the near-field application of these speakers, this is good to see.
Response is reasonable until -12/+12 dB (pink line). But when we go past that to -18/+18 we see that the shape changes so we lose our off-axis similarity around crossover region but regain it at higher frequencies.
Finally, here is the vertical directivity:
Audioengine A5+ Powered desktop monitor speaker Vertical Directivity Audio Measurement.png
Speaker Listening Tests
I tested the A5+ speaker on my test in the usual left position. It is on a 5 inch or so stand pointing up a few degrees. I have a "2-second" rule with speaker tests where I listen for the immediate reaction to the first track I play. It quickly sets in the impression for tonality. Here, the experience was good! No hand came out of the speaker and slap me to say, "I am too bright!"
That peak in bass was a good idea, providing clean impactful low bass hits. SPL (loudness) capability was also excellent. Yes, I could get it to distort but despite playing only one speaker, it could get surprisingly loud while maintaining that bass response. Gradually though, scratching sound would appear, telling you to back off.
I listened on and a lot of my reference tracks translated reasonably well but perfection was not there. The sound was a bit dull. So I went into Roon player EQ and started to add filters one by one. I wound up with three:
I added that broad increase centered around 300 Hz to make up for lack of energy there. I usually don't like increasing levels in EQ as that can push the speaker and lead to distortion. Not here. The subjective experience was definitely positive resulting in useful low frequency ambiance with almost no impact on how loud the A5+ could play.
Now the sound was a bit bright on some tracks. So I went after the high frequency resonance around 4.4 kHz. Knocked that down by 2 dB and that took care of most of that and cleaned up the highs a bit.
With that experience behind me, I figured I knock out the resonance around 900 Hz which happened to also coincide with peak distortion. Wow, that cleaned up the distortion very nicely without hardly any impact on tonality. You could so easily hear it in vocals and even higher frequency notes. Transient notes because much cleaner and less grungy for lack of a better word. I need to record this effect some day so you all know what I am hearing.
The combination of three filters transformed the A5+ from "OK and good" to "really good!" I sat there listening to track after track, enjoying each one of them. That nice bass was there now together with smooth, balanced response.
You can buy $100 powered monitors these days. So $400 seems quite a reach in the age of commoditization. Fortunately if you care about fidelity, the Audioengine A5+ delivers. It has higher than normal power and bass capability. And with a bit of equalization, produces truly high fidelity experience on your desktop.
As such, the Audioengine A5+ gets my recommendation and changes my opinion of the company/brand.
Since Sir @Thomas savage did not show up for his weed pulling duty during spring here in our yard, I had to buy a truckload of compost to put in our garden to keep the weeds down. The bill? A cool $1000! Needless to say, I feel quite poor now and badly need cash infusion. So reach deep in your pocket and donate what you can using : https://www.audiosciencereview.com/forum/index.php?threads/how-to-support-audio-science-review.8150/
  • Audioengine A5+ Spinorama.zip
Objectivist01
Good to know this is still a good speaker despite its hyped up subjective reviews ;)
Wes
Thx - I have been waiting for a review of this speaker.
I am now wondering about the effect of the bass port if the speaker were shoved all the way back into a corner...
Mine is not in a corner but a few inches from the rear wall. It worked fine there.
blueone
USA
I use a pair of the A5+ for my desktop computer system, with an SVS SB1000 sub. It took a little fiddling to get the combination right, but the integration is good enough that it sounds pretty seamless. When some deep bass does come along, and it's easy to forget the sub is there, it can be surprising. The best way I would describe the A5+ is that it does very little wrong within its bandpass. With a sub, they made a very livable HT system for my work apartment for several years. In white they look great with a Mac AIO too.
napilopez
NYC
This is a pleasant surprise, the A5's were one of the first speakers I was ever considered buying. Very nice performance considering they were released in 2011.
BDWoody
Chief Cat Herder
Moderator
Mid-Atlantic, USA. (Maryland)
Thank you for the review.
I really have enjoyed mine, and nice to see a solid review. Mine are in the kitchen...bamboo is one of the finishes.
maty
Tarragona (Spain)
I guess Zeos is much more sensitive to that bass dip, he just reviewed them yesterday and said:
"These are some of the most boring speakers ever."
I watched that before listening to my sample. He said his playlist didn't sound good. Mine did without EQ. I think he was beset with bias from his prior experiences at the show. Doesn't have my superior skills to put that aside. :D
blueone
USA
IMO, a properly integrated sub definitely makes for a transformation.
maty
Tarragona (Spain)
https://www.techspot.com/review/1595-audioengine-a5-plus-wireless-speakers/
[ For the A5+ Wireless, I measured this point to be right around 2KHz. The two separate outputs then drive the woofer and tweeter. Splitting up the audio this way allows for a better playback than a single speaker solution since each driver is tuned to a specific frequency. Considering how solid the external speaker wire was, I was a bit surprised at the thinness of the internal wiring. These aren't made to be ultra-powerful loudspeakers so it's probably not a big deal. What is good to see though is the ample acoustic padding to prevent echoing and internal vibrations. ]
[ Moving to the left speaker, we find all of the interesting components. Immediately noticeable is the massive toroidal power transformer that gives the A5+ Wireless a peak output of 150W. This style of transformer is more expensive than traditional "E" and "I" transformers, but they radiate less magnetic interference which can help cut down on noise... ]
muad
I wonder what is causing this retention of SPL off-axis between 800Hz-1kHz, as otherwise it has amazing directivity for the price, especially being an active speaker with a DAC.
I think it's just powered, not active. And I don't believe it has a dac built in?
