- Joined
- Oct 25, 2019
- Messages
- 11,135
- Likes
- 14,806
Pick the bones out of this!
https://positive-feedback.com/reviews/hardware-reviews/audioquest-fog-lifters/
It took him a full 11 paragraphs to finally get to the "cleared away the fog" metaphor. Audiophile, Schmaudiofile.
I achieve a degree of resolution every year around January 1st but the fog settles in by February or so"Even beginner audiophiles won't have any use for cable lifts" CORRECT!
"Only after you've achieved a sufficient degree of resolution will you hear what they can do."
Ask them to send a set to Amir to test.
I want my click back.
and after you bought couple of lifters, then you must buy The Extender!
https://positive-feedback.com/audio-discourse/impressions-van-den-hul-the-extender/
5 GRAND A PAIR!!!!!!
I've heard being an audiophool is an expensive hobby
I liked the bit about the 1ms delay caused by RFI. Possibly even group delay.Pick the bones out of this!
’That doesn't mean RFI is innocuous—far from it. If it gets into a component, the signal will appear altered and accurate processing will be compromised, most likely manifesting as messed-up timing. For example, the lower-midrange might be delayed a millisecond, then linger around too long. Frequency coherency gets out of sync causing smearing and blurry conditions—in other words, fog. That is exactly what the Fog Lifters remediate.’
In 40 years designing ICs and RF ICs I never came across this phenomenon - guess I must have missed something
