JayGilb
Any speaker can be used for an accurate mixing monitor if the mix engineer learns how it sounds using reference mixes and many hours of use.
Yeah, but why?Any speaker can be used for an accurate mixing monitor if the mix engineer learns how it sounds using reference mixes and many hours of use.
learning to work on accurate (but that's debatable when measured in room) monitor takes as much time, it's only faster when switching from say Neumann to Genelec, or changing smaller to bigger model. NS10 popularity was more about using the same tools as successful people than it's sound, then it became more about them being the standard equipment that always sounded familiar (in a bad way, but still).Yeah, but why?
Most informative, but I have to ask: why would you buy such a thing?This is a review, listening tests and detailed measurements of the Avantone CLA-10 which is made to be a clone of the famous Yamaha NS-10A monitor. I purchased it from Amazon and costs US $699 (a pair).
We have the iconic paper white woofer. Speaker is commonly shown the horizontal configuration as you see but I tested it vertically as you see below. No port or anything exciting in the back:
The claim to fame of the original Yamaha NS-10m was that it would allow mix/mastering engineers to create pop/rock music that "translated" well to whatever people were using to listen to music. A bit of its history and anechoic measurements are documented in this excellent paper:
THE YAMAHA NS10M: TWENTY YEARS A REFERENCE MONITOR. WHY?
Philip R Newell Consultant,
Moaña, Spain Keith R Holland ISVR, University of Southampton, UK
Julius P Newell Independent Audio Systems Engineer, UK
Here are their conclusions:
6. SUMMARY
From the investigations presented, and from experiences in the use of the NS10M, it would appear that the following statements can be made.
•The free-field frequency response of the NS10M gives rise to a response in typical use which has been recognised by many recording personnel as being what they need for pop / rock music mixing. The principal characteristics are the raised mid-range, the gentle top-end rolloff, and the very fast low-frequency decay; the latter is aided by the 12dB / octave roll-off of the sealed-box cabinet.
•The time response exhibits a better than average step function response, which implies good reproduction of transients. Many people speak of the "rock and roll punch" of the NS10M. •The distortion characteristics are also better than average for a loudspeaker of such size.
•The output SPL is adequate for close-field studio monitoring with adequate reliability.
•In many of these characteristics, the NS10M mimics the response of many good larger monitor systems in well-controlled rooms. They are hence recognisable to many recording personnel in terms of their overall response.
•They are tools to achieve a well-balanced mix. It is notable how many of the people who use them in studios do not use them for home listening.
I tried to find a real NS-10m on various auction sites but all I found were speakers in horrible shape and still asking what this Avantone more or less costs. Testing the old samples would not give us data on how they performed when new so made no sense to risk buying them.
As noted, I chose to test the CLA-10 vertically as it was easier to set the reference point on Klippel NFS. Otherwise I would have to shift the speaker to the right, making for an asymmetrical situation. Fortunately this doesn't impact on-axis response and you can just transpose vertical measurements for horizontal and get that data as well (can't do that with preference score but that is not a big thing here).
Tweeter center was the reference axis although it did not make much difference when I lowered it.
Avantone CLA-10 Speaker Measurements
Let's start with the anechoic measurements from the Newell, et. al. paper of the Yamaha NS-10M:
We see that it has a hugely over boosted midrange to low treble. We get that in CLA-10 but unfortunately here, the boosted response goes way higher:
So assuming the paper measurements are correct, then the CLA-10 clearly is not its clone. That aside, there is a narrow but nasty resonance around 3500 Hz. We have a large directivity error that would have been in the Yamaha as well. Overall, this is a horribly bad response by any measure.
Strangely that resonance did not show up in near-field measurements indicating it likely is not in the drivers:
Paper talks about low distortion but they measured it at 90 dBSPL so not matching mine. But we can interpolate and kind of see what they are saying:
We really need relative distortion measurements as that includes the variations in response. Absolute levels as they show is not instructive unless speakers being compared all have flat measurements (which they do not). Using our relative measurements, we see broad distortions where our hearing is most sensitive at 96 dBSPL.
We see the strong directivity error impacting our early window reflection sum:
Breaking that down we see that using the speaker as tested, i.e. vertically, is much more optimal:
As noted, the pink curve which is the sound being sent to you, going past and reflecting from the wall behind you (if it is close), makes the tweeter even hotter so absorption there would help.
If you placed the speaker on its side the right graph becomes your horizontal axis, emphasizing that massive error. You better absorb the heck out of your sidewalls then (assuming they are close to the speakers).
Here is our predicted in-room response:
We see the effect of directivity error in our 3-D near-field plot:
Level of reflections in the room will change the tonality of this speaker fair bit.
Our beamwidth and directivity tell the story we already know:
The paper talks about fast settling response of the Yamaha NS-10 but they use wildly different timing scale so we can't compare that to my measurements (they can do that because they have an anechoic chamber). Here is the data anyway:
So we don't just have boosted frequencies but lots of resonances within. I think this is the worse waterfall measurement I have seen of any speaker I have tested.
The paper also has a step response and here, matching to our measurements is excellent:
Rating impedance of the original I think is 8 ohm and we are kind of there with CLA-10:
Avantone Pro CLA-10 Speaker Listening Tests
I was listening to my everyday music when I started to test the CLA-10. When I hit play on the same track I was listening to using my headphones, I thought something was seriously wrong as all I was hearing was distorted high frequencies. I went back to my standard test tracks and there, the sound was somewhat better but as you can imagine, had heavy treble emphasis. Not only that, it sounded grungy and bad. I dialed in an inverse filter for the 3450 Hz resonance and that cleaned things up a bit. From there, I built a five filter correction but the speaker still sounded quite lousy.
I then took the inverse approach of boosting bass. That was more successful but still, what I was hearing was just not great. The sound and experience was bad that I just gave up on playing with it more. The idea here is not to make this a hi-fi speaker anyway as the use is for mastering and everyone says it is not good for enjoyment. On that front, they are right.
I did experiment with putting in a shelving filter to bring the response close to the NS-10m and that was definitely an improvement. So I don't think the Yamaha was nearly as bad as CLA-10 is. I like to meet the mastering engineering who was involved the design of CLA-10 to understand how he thinks these speakers are equivalent.
Discussion and Conclusions
The data here seems clear: in attempting to clone a rather broken speaker, Avantone has made an even more broken speaker. It fails not only in mimicking the frequency response of the NS-10M but seems to also introduce resonances that may not have been in the original. Any attempt like this should have been done as you see above: with detailed anechoic measurements to make sure the design is a true clone of the original. Using what is thought to be original parts and tuning based on someone's ear is just not the way to do it.
The whole idea of a mix that "translates well" is a problematic thing. Yeh, in the 1970s and 1980s we listened to a lot of music in cars with stock sound systems and clock radios and such at home. Those systems were likely to have had midrange/lower treble emphasis. That all changed with advent of iPods and people listening to headphones/IEMs that have deep bass response. So likely what translated to old casual audio systems of the past, will not work in this era. Why there is still interest in buying such a speaker is beyond me.
I know I may be making a lot of enemies by saying this but maybe this speaker was compensating for poor listening skills of people using them. That is, unless there was so much exaggeration in large portion of the frequency response, they couldn't tell that they had boosted them too much in the mix/mastering.
The massive directivity error just adds to the problem. No wonder folks were covering all the walls in their studios. They couldn't stand the sound otherwise!
If I were to listen to this speaker to tune a mix, I would have to turn so much of the gain from upper midrange to treble. It is so grating otherwise. The mix then would sound absolutely dull on any half proper audio system. The industry needs to ditch this concept and adopt fully neutral audio systems used in mixing/mastering systems. Then we can adopt the same and be on the same wavelength.
Anyway, I am out $750 including tax so hopefully you found this analysis and measurements of value!
Needless to say, I can't recommend the Avantone CLA-10 monitor.
Specifications
- SYSTEM TYPE: Passive - full-range two-way stereo pair
- FREQUENCY RESPONSE: 60Hz-20,000Hz (Accessible musical range)
- POWER CAPACITY: Program – 60W, Maximum – 120W
- SENSITIVITY: 90dB SPL (1W, 1m on axis)
- COMPONENTS:
- Low Frequency: AV10-MLF 18cm cone
- High Frequency: AV10-MHF 3.5cm soft dome
- CABINET: 10.4 liter sealed design, 18mm MDF with real wood veneer
- CABINET DIMENSIONS: 381.5mm x 215mm x197.5mm ( 15”x 8 ½”x 7- ¾ ” )
- CABINET WEIGHT: 6.3kg / 13.9 Lbs (each)
- WARRANTY: 5 Year Limited Warranty to original purchaser
As always, questions, comments, recommendations, etc. are welcome. Click here if you have some audio gear you want me to test.
Because they have the same reference wherever they go to record. A reference does not have to have high quality, all it needs is a repeatability of performance.Yeah, but why?
On www.kleinanzeigen.de there are 9 pairs available in Germany as of this writing. And one pair of 615. Just saying....locally (EU) I don't see any ns10 currently for sale, but I see a pair of ns615 for ~$300
I never understood this point: why not use a monitor with a right tonal balance in the first place instead of mixing low mids and mids on a "broken speaker" like the NS 10 and than going back to another speaker to adjust lows and highs?
there are actually two pairs of NS615 and both for around 250€, all NS10 pairs are for upwards of 600€, so this confirms what I said that if you can't find a pair of NS10 for a good price, NS615 are a cheaper alternative at almost a third of a costOn www.kleinanzeigen.de there are 9 pairs available in Germany as of this writing. And one pair of 615. Just saying....
I have. Not common, but I have. They sound nothing like the originals I've heard. Way, way brighter.For a start, I have never seen this Avantone in a commercial studio.
That is a myth ventilated every other day. Many sound engineers are as mislead as consumers by preconceptions, fixation on brands and well, misunderstood technological wonders which are mostly just wishful thinking. ( e/g banana fibre cone )I guess if you like nothing Bob Clearmountain has produced then you comments may be true.. but he insisted on NS10s to check the quality of his productions ...
Thing is, many people don't care that much about the correct stereo setup, themselves included sitting 'right in the middle' all the time, not moving the ears a bit ... . Because it would be ... better won't say.It was a high quality 'mini' speaker made for Japan (and likely their musical tastes...) in their NS (Natural Sound) speaker range to be used with the emerging smaller footprint home/shelf type systems ... not an enjoyable speaker.
The NS10 is NOT a 'broken speaker' - at least, not in the original domestic context either side of a stack system and sat on a bookshelf!!! Just 'cos they don't suit the current 'Klippel friendly' boxes raved about here doesn't mean they can't be used as a production/general reference tool. I mean, look at the LS3/5A, a 'to me' ghastly shrill tizz box, yet they fulfilled their original OB-van role superbly and as a small general 'sound box' in broadcast studios until replaced by the (almost as bad to me) Dynaudio BM5A and similar models...I never understood this point: why not use a monitor with a right tonal balance in the first place instead of mixing low mids and mids on a "broken speaker" like the NS 10 and than going back to another speaker to adjust lows and highs?
you'll send them back or sell them, right?Anyway, I am out $750 including tax so hopefully you found this analysis and measurements of value!
I still keep on wondering how a totally unbalanced monitor should translate well in a mix universally. Maybe I'm dull but to me it's utterly bullshit.
