This one seems to be good too https://www.audiophonics.fr/fr/born...c-plaque-or-o16mm-x-61mm-la-paire-p-9899.html well too
Nice, anyone know the bolt size and length for the 3e boards
Wanted to know the required length, wasn't clear apologies.@brunes M3, plz check user manual also.
heatsink is 10mm thickness, 5mm reserve for mounting.Wanted to know the required length, wasn't clear apologies.
i think so.Question, If I want to wire in parallel do I just duplicate the cables to the IEC (obv. from the other side) and do the same for the switch. e.g. as if I was to run a single SMPS and Switch and double the wiring ?
Hi - this looks like a great project - your build looks great!
Do you know if I could drive this from a Topping E50?
thanks!
Is it deafult out 5vrms for xlr or can it be changed( i got the same)Get the SMSL D6S instead
XLR outs can be set @5Vrms or 4Vrms >If you have other projects in the future, it will therefore remain more flexible
@5Vrms this DAC performs about 124db SINAD ! awesome )
SMSL D-6s Balanced DAC Review
This is a review and detailed measurements of the SMSL D-6s balanced stereo DAC with Bluetooth support. It was sent to me by the company and costs US $199. I was pleasantly surprised with the new industrial design which while minimalistic, manages to impress with its modern style. Love the matt...www.audiosciencereview.com
