"Bamboo Project" : Dual Mono 3E Audio 480-1-29A Amplifier
Hjbct
So in either case, the DAC acts as the pre-amp ? no other pre-amp needed?
daniboun
daniboun
France (Lyon)
Right we can say that. I only have this dac on my system.
Frider
Translated by moderator. Please post in English going forward. Thanks!
Good morning
Can we use a classic regulated power supply, transformer + capacitor.
THANKS
brunes
I got scared by another post of DACs doing max volume...
Made a preamp using a neurochrome universal buffer.
Weak point of a cheap Alps pot...
brunes
Also, do I understand only at max volume do you get highest output (5v) of the DAC, how do.you do this without a preamp?
daniboun
daniboun
France (Lyon)
Good morning
THANKS
Hi
Yes you can use a linear PSU + rectifier board.
Use 43V max for unregulated psu.
daniboun
daniboun
France (Lyon)
Checkout attached file from this review
  • SMSL D-6S MQA Audio DAC stereo balanced XLR SINAD vs Level measurement.png
trungdtmc
I have measured between a PFC LLC power supply and a non-PFC LLC on A07 max, and the result is that the power supply with PFC is noisier, higher THD+N than the non-PFC.
antcollinet
UK/Cheshire
That is not a particular surprise. The PFC circuit is of course a switching circuit, and therefore may well introduce additional noise.
However, bear in mind that the result might not be due to the PFC. It is a different PSU, so the overall PSU design might be noisier - or even just component tolerances may be the cause. You also have a test group of only one of each device. Far from enough to draw any conclusions.
Finally : the old adage "correlation is not causation" applies.
Roland68
Cologne, Germany
Both power supplies look like very cheap Aliexpress (or similar) products. There seem to be very different power supplies.
Are there data sheets for the power supplies?
trungdtmc
I bought both directly from taobao, which is the original supplier and has all the specifications. Aliexpress stores are mostly resellers, like the one where Dan bought it
daniboun
daniboun
France (Lyon)
Dont get me wrong :
The MP-H250S48 is only PFC not LLC...
The other is only LLC. I used it with my first Sylph audio amp too )
daniboun
daniboun
France (Lyon)
Will check this soon ) The Micro audio has no PFC and no LLC circuit. This will tell us if the simpler is the better )
antcollinet
UK/Cheshire
Not really - it will only tell you if that particular simple PSU is better :cool:
daniboun
daniboun
France (Lyon)
Chinese sites say anything and everything)
Check here what a LLC + PSU + Soft Start PSU looks like :
daniboun
daniboun
France (Lyon)
True ) BTW, the Amplifier is on the way to Germany.
It scares me a little to entrust my amp to a company I don't know but hey... I like taking risks lol
trungdtmc
they are the manufacturers of these power supplies
